G
Guest
Guest
ok here it goes, so a year ago i let this guy build my computer and he put a ridiculous amount of thermal paste on my cpu causing it to go to high temperatures. so i just now decided i would reapply the themal paste with artic 5. so as i try to take the heatsink off the cpu, the cpu comes off with it!
so i check if any pins are bent, luckily none are, but the heatink was stuck to the cpu, because so much thermal paste was used. so i read around alot of the the people say to use the blow drier method i tried that but it didnt work the cpu wouldnt even budge. so one guy said to dunk the cpu and the heatink in aisoportoyal alchol and i tried that and it worked!. so i cleaned the heatsink and cpu but ther was still stains i couldnt get off. so i said *** it, and just reapplied the artic 5 thermal paste. i put like a pea drop and put everything back together but now the computer wont boot up.....
wtf. the cpu fan spins and everything but the computer wont boot up. like the windows screen wont boot up.
