Hi friends, I am first at Tom's. Please do guide me through the problem!
First I will give you the info-
My system specs---
# A GA-M61PME-S2P motherboard
# 2 GB kingston DDR2 RAM( will upgrade to 4 GB)
# An AMD Athlon 2 X2 245 CPU
# An Intex 450 W PSU (bundled)
# A PCI-E x16 slot
# LG Monitor with max 1400 X 900 resolution.
More info about my PSU....
This is exctly what is written on my PSU..
Smart IT-2045S+
450 Watt, 20+4 Pin , 1 SATA , 3HDD , 1 FDD, 1 FAN.
AC INPUT: 220V 50Hz 5A
DC OUTPUT: +3.3V: 30 A +5V: 29A+12V: 18 A -12V:0.5 A +5VSB:2A
ATX 2.03
Now the question is if my PSU will handle an hd 6670 or not. If it will, which brand should I buy( Sapphire, XFX etc.). Also tell me if the card will be compatible for my PC or not!
I don't want to upgrade my PSU so if my PSU will not handle 6670, please suggest me another card!
Any help will be greatly appreciated! I have been using an 8400GS which has a TDP of 45 W and the HD 6670 has a maximum TDP of 63W. So, I think that it won't make such a difference!
My system specs---
# A PCI-E x16 slot
Smart IT-2045S+
ATX 2.03
