Gateway PC 834GM will not boot up. Power light turns on, fans are running, green
  • Power Supplies
  • Power
  • Light
  • Boot
  • Green
  • Gateway
  • Components
Last response: in Components
July 16, 2012 3:28:02 AM
Hello,
Is there a test to perform to identify if problem is the power button/switch or power supply or could it be some other issue?
More about : gateway 834gm boot power light turns fans running green
a b ) Power supply
July 16, 2012 4:40:09 AM
it could be a number of things
do you have another system you can test components on like the CPU (must be the same socket) and the ram (must have DDR support)
whew, a 56K modem... lol
m
l
July 23, 2012 2:36:45 AM
No, my other computer is a laptop. I guess I'll purchase a new power supply and start there. Thanks for suggestion.
m
l
