Gateway PC 834GM will not boot up. Power light turns on, fans are running, green
  • Power Supplies
  • Power
  • Light
  • Boot
  • Green
  • Gateway
  • Components
Last response: in Components
July 16, 2012 3:27:50 AM
Hello,
Is there a test to perform to identify if problem is the power button/switch or power supply or could it be some other issue?
More about : gateway 834gm boot power light turns fans running green
a c 167 ) Power supply
July 23, 2012 8:11:56 PM
Have you ever changed your CMOS battery on the motherboard? If it dies, your PC won't be able to boot.
m
l
