Problem With Radeon 6850
Hello, I am Banish25.
I have a problem when i installed my new MSI cyclone 6850 and I got a Warning System BOOT Fail.
I am sure it is the graphic card because when i took it out, the warning did not display.
My components are:
Power Supply: 650 W
Motherboard: Asus P5n73 - AM (with a Geforce 7050)
CPU: Dual Core @ 2.6 GHz
RAM: 2x 2 GB DDR2
Things I tried WITHOUT success
I tried resetting CMOS by removing the battery and using the jumper
update bios is version 0801 (latest)
I have tried to remove power from CD/HD
Disabling and uninstalling onboard VGA
Removing a stick of RAM
Note: I have connected the 6 pin power to my MSI 6850. I do get a black screen when I direct connect to my MSI 6850
More about : problem radeon 6850
a broken card is better than the pci express 1.0 issue. since you already updated the bios, if it is that issue you will be out of luck with all pci 2.1 cards.
only real way to test it is put the card in another system if you can.
Related ressources
Ask the community
