HTPC Build (mix and match with some old parts)
Hello
My old gigabyte motherboard died on me recently and decided to upgrade to a sandy bridge platform. However this has left me with a perfectly working Core i5 760 which I have decided to be the basis of a HTPC build. I understand that the lga 1156 platform is now essentially dead and support is limited interms of motherboards but I am happy to purchase one on ebay.
Approximate Purchase Date: within the next month
Budget Range: no more than AUD$350
System Usage from Most to Least Important: watching movies
Parts Not Required: Keyboard, mouse, graphics card (old 4650 full height), HDD, optical
Preferred Website(s) for Parts: auspcmarket, msy, pcdiy, ebay if needed
Country: Australia
Parts Preferences: No real preference
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080
Additional Comments: I would like it to be as small as possible! Also my dad has a 5770 in his computer which he does not use so I could swap the 4650 for the 5770 if needed (all he does is check his email)
Parts that I have been looking at
Zotac H55 - ITX -C - $147
http://www.ebay.com.au/itm/NEW-ZOTAC-H55ITX-C-E-Intel-LGA-1156-H55-Mini-ITX-WiFi-MOTHERBOARD-/260986207033?pt=AU_Components&hash=item3cc3fd7b39
AYWUN MI-100 MINI-ITX CUBE CASE $63.90
http://www.auspcmarket.com.au/info/AL-A1-MI-100/371/
Patriot Signature 4GB - $24
http://www.msy.com.au/product.jsp?productId=5177
TOTAL: $234.90
My main concerns are
1. The case/power supply. I build alot of ATX sized computers and I know the importance of airflow/power efficiency. I assume these powersupplies aren't fantastic but will they get the job done
2. Will the stock cooler fit ok in this case?
1 answer Last reply
More about htpc build match parts
  1. Oh I have a spare antec TP-550 if that helps
New Build Systems
