Buying some used parts -- need advice on build. <3
Last response: in Systems
April 2, 2012 4:55:00 PM
The goal of this build is to play BF3 on High-ish. Budget is $300-350.
I already have a 500GB HDD, disc drive, case, etc. Want to upgrade mobo, RAM, CPU, and GPU.
I have a 500 watt modular PSU. I'm pretty sure it can handle newer parts but if not please let me know! :D
I am planning on buying some used parts off a friend.
He is offering the following for $100.00.
Mobo
CPU
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E168... (barely used)
My main concern is the micro-atx motherboard. I am pretty sure it will fit in my case but not positive? I've never used micro-atx.
The processor seems decent. I've found processors in that range selling for about $100 new.
I'm looking to buy a new GPU.
If those used parts are good then I'm considering buying:
or something similar
If I have to buy a new mobo or something:
or something similar.
Thanks guys!
Edit
I found a GTX 480 used for 200 bucks. That seems like it might be the right buy.
April 2, 2012 6:23:24 PM
A micro ATX board will fit in your case. You will have to move/remove a couple of the little brass standoffs in you case and it will fit fine.
That is a fairly budget Board and CPU and Ram.
Should still work for what your budget is.
m
l
April 2, 2012 11:19:40 PM
Will I have any cooling issues with a micro ATX?
Do you think the GTX 480 will fit in fine etc?
Am I going to bottleneck?
m
l
April 3, 2012 12:09:53 AM
There should be no cooling issues with a micro ATX board. And yes a GTX 480 will fit.
As far as bottlenecking.... I doubt it. Only testing will show that. Maybe someone with more personal experience on one of them can enlighten us....
m
l
April 3, 2012 12:45:39 AM
My friend is convinced that I can't mount a GPU on the micro ATX board.
You're saying it should be fine?
thinking about buying an http://www.newegg.com/Product/Product.aspx?Item=N82E168... GPU
and a http://www.newegg.com/Product/Product.aspx?Item=N82E168...
board.
Thoughts? Is the cheaper build (with the micro ATX board) a better deal? I could probably get the used processor and the RAM for $50.
It might be worth mentioning that I realized that the mobo isn't compatible with DX11. I'm trying to find one that is.
m
l
April 3, 2012 2:49:41 AM
Here are your specs:
Learn more about the GIGABYTE GA-M68MT-S2
Brand
GIGABYTE
Model
GA-M68MT-S2
Supported CPU
CPU Socket Type
AM3+
CPU Type
FX / Phenom II / Athlon II / Sempron 100 Series
FSB
1000MHz Hyper Transport (2000 MT/s)
Chipsets
North Bridge
NVIDIA GeForce 7025/nForce 630a chipset
Memory
Number of Memory Slots
2×240pin
Memory Standard
DDR3 1600 / 1333 / 1066 / 800
Maximum Memory Supported
8GB
Channel Supported
Dual Channel
Expansion Slots
PCI Express x16 This is the 1 slot for a GPU
PCI Express x1
PCI Slots
Storage Devices
SATA 3Gb/s
4
SATA RAID
0/1/5/10/JBOD
Onboard Video
Onboard Video Chipset
NVIDIA GeForce 7025
Onboard Audio
Audio Chipset
Realtek ALC887
Audio Channels
8 Channels
Onboard LAN
LAN Chipset
Realtek 8211CL
Max LAN Speed
10/100/1000Mbps
Rear Panel Ports
PS/2
COM
Video Ports
D-Sub
USB 1.1/2.0
4 x USB 2.0
Audio Ports
3 Ports
Internal I/O Connectors
Onboard USB
6 x USB 2.0
Other Connectors
1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x CPU fan header
1 x system fan header
1 x front panel header
1 x front panel audio header
1 x parallel port connector
1 x clearing CMOS jumper
Physical Spec
Form Factor
Micro ATX
Dimensions
9.6" x 8.07"
Power Pin
24 Pin
Features
Features
Get Ready for New Generation of 32nm AMD AM3+ CPU
Supports next generation of 45nm AMD AM3 CPU
On/Off Charge Technology
Core Boost Support
NVIDIA GeForce 7025 / NVIDIA nForce 630a GPU
DualBIOS - Dual Hardware BIOS Protection
m
l
April 3, 2012 2:57:56 AM
Yes that ASUS board is nicer.. the GPU is a little slower then a GTX 480 (according to toms anyway. I have not tested it)
It all depends on your budget.
The 3 items you listed in your first post will all combine to make a functioning computer. Yes there is much better parts out there, But if your on a budget you are on a budget.
I have personally used a micro ATX board with a dual slot GPU before. That will work.
m
l
April 11, 2012 4:17:10 PM
If I had to get a new PSU what would you recommend?
The Tom's round up lists the 7850 as being a sweet deal. At $260 that's all my budget so I'd be using those cheap used parts.
My concern is that the cheap cpu/mobo might make getting a card that powerful worthless by holding it back its performance. Will I be able to get the same FPS in BF3 as the benchmarks on Tom's? (50ish on high?)
If the 7850 won't work well then I could probably settle with a 6870.
m
l
