hi,
So I am a system builder and make a tidy some every year on the side constructing PCs.
On a computer I currently have under-construction for a client I have a massive problem.
When I attempt to power on the system, it does nothing. No BIOS, no fans turning, just nothing.
So, I have stripped down the system to a PSU that I know works, the motherboard, the CPU, and one stick of good RAM.
Since I know the PSU, RAM work I figure the problem must be in the motherboard or the CPU.
They are a 3930K and an ASUS p9x79-both brand new.
Is my only recourse to RMA them both and pray for the best?
The only explanation other than one of the two or both being DOA that I can think of is that I have switched out the CPU clamp and I do not know if the new X79 has some sort of sensor to detect how firmly the CPU is planted and prevents the computer from spinning up if it is not (sounds unlikely).
Forgot to mention, the speaker on the front panel connectors doesn't even give me an error code/sequence of beeps.
Any ideas? If I can't fix this today, I'm RMAing both parts.
CC
CC
