Sound keeps glitching/stuttering
  • Sound Cards
  • Video
  • Components
Last response: in Components
July 16, 2012 4:37:52 PM
I have been having this problem for a while now, at first it was just every now and then, I though there was no need to worry about it, then it became unbearable, happening every 10 seconds or so. I thought a fresh install would fix it, but to no avail. This problem also seems to correlate with my video as well, either if I am on youtube or playing a game, if the sound glitches, then so does the video, making almost anything I do unbearable. Any help with this problem would be greatly appreciated. I have also been doing research on this as well and this is NOT a sound problem with static noises.
More about : sound glitching stuttering
July 17, 2012 7:40:55 PM
Check the drivers are updated. If it doesnt work reinstall the drivers. If it doesnt work check for viruses. If it doesnt work buy a new sound card or look with Uncle Goggle :)
Good Luck!
m
l
July 26, 2012 4:49:24 PM
Sounds like your getting latency spikes. Download "DPC Latency Checker" and let me know your findings and what mother board your using. Maybe I can help.
m
l
July 26, 2012 6:46:09 PM
If its lag spikes then check your network settings. Use Namebench to check for the best DNS and donwload the Leatrix Latency Fix for high ping or lag.
m
l
