Will these components work?!?! (first build)
- Build
Components
Systems
- Product
Last response: in Systems
PCN00B
April 3, 2012 10:25:07 AM
hi, this is my first build ever and have done research and decided on these components. I'd like to know if they are fully compatible (i think they are), if it will fit in the case and if i'd be better off with different components. I will be using this pc for gaming, running bf3 on best or there about graphic settings.
CPU- AMD FX 6100
GPU- Gigabyte radeon hd 6850
MOBO- asus m5a97 evo
RAM- G.SKILL Sniper low voltage series 8 gb (2 x 4gb)
HDD- western digital caviar blue 500gb
optical drive- ASUS 24X DVD Burner
Any advice would be greatly appreciated thanks.
CPU- AMD FX 6100
More about : components work build
Chaz21
April 3, 2012 10:50:02 AM
PCN00B said:
hi, this is my first build ever and have done research and decided on these components. I'd like to know if they are fully compatible (i think they are), if it will fit in the case and if i'd be better off with different components. I will be using this pc for gaming, running bf3 on best or there about graphic settings.CPU- AMD FX 6100
Question 1 = Yes
Question 2 = ? (You didn't tell us the case).
Question 3 = Yes. You'd be better off with these:
and IMO these:
but either way don't forget one of these:
PCN00B
April 3, 2012 11:05:03 AM
- Do my chosen components for my first build work ?? - Forum
- Before i order these components for building my first pc will these components fit together/work? - Forum
- Will these components work? First build, lots of questions - Forum
- First PC Build. Will these components work together? - Forum
- Will these components all work? First full PC build! - Forum
PCN00B
April 3, 2012 11:07:11 AM
Chaz21
April 3, 2012 11:36:19 AM
PCN00B said:
soz i forgot alot of things. case- Raidmax aeolus vl version psu- any 750 watt psu i find on a uk site and will i be able to overclock the psu to nearer 4 ghz without an aftermarket heat sink fan just using the case fans 3 intake 3 outtakeFirst things first.
I would never suggest overclocking without a good CPU cooler. Hyper 212 ('s) are good.
Your case choice is fine. I like the haf 912 myself.
Staying within your budget is important these days. While not my choices your selections will accomplish what you want them to do.
Last but not least do not just buy any 750 watt PSU! More problems are caused by cheap and faulty PSU's than most anything else. Get a good name brand model (Antec, Corsair, Seasonic -etc.) you won't regret it. Good luck with your build.
unknown_13
April 3, 2012 12:03:48 PM
What is your budget and can you buy from newegg? I'm asking you because Bulldozer cpu's are crap compared to Sandy Bridge, and i'd recommend a SB build but i gotta know your budget before i recommend parts.
Also, what's your current PSU?
Chaz21
April 3, 2012 12:16:36 PM
unknown_13
April 3, 2012 1:03:36 PM
Chaz21
April 3, 2012 1:36:06 PM
PCN00B
April 3, 2012 1:39:12 PM
i think for price/performance and to cope with games my best bet is probably the fx 6100 but thanks for you advice anyway
and i can buy from newegg its not much of a problem. Chaz do u know a good retailer for psu's that has the uk 3 prong plug and a bit of a side question i think i know the answer but do psu's come with a ac power cord? thanks again for everyone's advice it has really helped
Chaz21
April 3, 2012 1:50:03 PM
and i can buy from newegg its not much of a problem. Chaz do u know a good retailer for psu's that has the uk 3 prong plug and a bit of a side question i think i know the answer but do psu's come with a ac power cord? thanks again for everyone's advice it has really helpedGood ones come with the cord. Look this site over:
http://www.overclockers.co.uk/productlist.php?groupid=7...
I'm not all that familiar with UK suppliers. Hope the site helps.
Chaz21
April 3, 2012 2:03:35 PM
Quote:
Link me to the HDDAre you asking for this?
http://www.amazon.co.uk/Western-Digital-Caviar-Internal...
if that's not where he's getting it at least it's in the UK.
Hydroc10
April 3, 2012 2:22:49 PM
unknown_13
April 3, 2012 2:27:35 PM
Mechanical drives don't benefit at all from SATA3, only fast SSD's.
Chaz21
April 3, 2012 2:31:50 PM
Hydroc10 said:
For games your better off going with a Phenom II 965 but you would need a cooler because the fan is loud and you'll wish you did. If you can save $20 by going with 2x2gb ram that would get you a 6870. Thats my advice.I would agree with your choice of CPU over the FX 6100 but I'd keep the RAM.
PCN00B
April 3, 2012 5:07:48 PM
here is a link to the hdd http://www.newegg.com/Product/Product.aspx?Item=N82E168... I dont understand why you think the phenom is better the only thing i can see is it has 0.1 ghz more but i can easily overclock the fx to that
PCN00B
April 3, 2012 5:25:26 PM
http://secure.newegg.com/WishList/PublicWishDetail.aspx... this is the newegg wishlist for almost everything excluding case and psu if this helps at all
Chaz21
April 3, 2012 5:26:53 PM
PCN00B said:
here is a link to the hdd http://www.newegg.com/Product/Product.aspx?Item=N82E168... I dont understand why you think the phenom is better the only thing i can see is it has 0.1 ghz more but i can easily overclock the fx to thatThis is one of many similar:
http://www.techradar.com/reviews/pc-mac/pc-components/p...
but I believe you should get what you will be happy with. It's your PC after all not ours!
Hydroc10
April 3, 2012 5:44:20 PM
PCN00B
April 3, 2012 6:35:45 PM
hmm i see ur point but the 1100t isnt in stock anywhere and the 1045t only runs at 2.7 ghz i read the review on this site http://forums.overclockers.co.uk/showthread.php?t=18374... and it appears in multi threaded applications it does a bit better so its a bit of a toss up but i think i'll go with the fx cause its unlocked and easily over clockable, that and i've based al my other choices around it but thanks for the help and i'll just chance it. btw anyone know a good aftermarket cpu cooler thx
Chaz21
April 3, 2012 6:44:02 PM
azeem40
April 3, 2012 6:44:38 PM
PCN00B
April 3, 2012 7:07:54 PM
thanks chaz will prob be gettin it now. azeem gaming is mostly multi threaded it is pretty good http://forums.overclockers.co.uk/showthread.php?t=18374... and way easier to overclock, could u give me some reasons that have some foundations to them as to why i should change to an i3 system rather than just "fx suck"
azeem40
April 3, 2012 7:13:16 PM
PCN00B
April 3, 2012 7:16:54 PM
Chaz21
April 3, 2012 7:17:56 PM
PCN00B
April 3, 2012 7:20:18 PM
Chaz21
April 3, 2012 7:24:09 PM
PCN00B said:
i thought that aswell but i guess the cpu would be a factor aswell. oh btw chaz do u know what kind of settings battlefield will be able to run with using the radeon hd 6850?http://www.guru3d.com/article/battlefield-3-vga-and-cpu...
This what your looking for?
PCN00B
April 3, 2012 7:30:43 PM
ttg_Avenged
April 3, 2012 7:40:41 PM
PCN00B said:
oh and id like to build for under £500 so thats why im going amd cause it alot cheaper. (i'm forgetting alot of things today)What the first poster said, go with him. Intel, sorry if your a fanboy, is greater than AMD BUT! Only for the higher budgets. AMD FX 6100 is a damn good chip, just expect to buy a fan because the stock's are garbage. (You might even have to UNERclock lol.) Also honestly did you pick that due to 6 cores? Not one single game is optimized for 6-core and wont be until late 2013 or early 2014. Your graphics card will handle BF3 @ 60fps @ medium-high settings. NOT ultra. I have a 560 Ti and only get 46FPSish oc'ed. What you have, if your chuck it into a case, yup it will turn on. Have fun building as it is a great learning experience. I just built this 1300$ beast last last weekend.
Chaz21
April 3, 2012 7:40:46 PM
PCN00B said:
yes but sadly not the results i was hoping for u know a gpu for around the same price £20 more at tops probs that would deliver better performanceSee what it's on par with here:
http://www.tomshardware.com/reviews/gaming-graphics-car...
PCN00B
April 3, 2012 8:27:25 PM
right i've decided im gonna save up a bit longer and get the radeon hd 6870 so i don't end up buying a new gpu in 2 months and waste money. ttg avenged are u sayin i should buy intel or amd im confused and yeah i thought i should get the 6 core instead of the quad cause i thought it would be better and the standard in the future i want this pc to last me a good 5 years before i replace it
Chaz21
April 3, 2012 8:36:29 PM
PCN00B said:
right i've decided im gonna save up a bit longer and get the radeon hd 6870 so i don't end up buying a new gpu in 2 months and waste money. ttg avenged are u sayin i should buy intel or amd im confused and yeah i thought i should get the 6 core instead of the quad cause i thought it would be better and the standard in the future i want this pc to last me a good 5 years before i replace itI think we're all telling you that but as I told you above get what you want - what makes you happy.
PCN00B
April 4, 2012 10:54:57 AM
Chaz21
April 4, 2012 11:05:00 AM
PCN00B said:
what makes me happy is a pc that will be able to run the games that come out in a year in top graphic detail but that is under £500 changing the video card to a slightly more expensive one that's in budget and will deliver what i want is perfect so thanks to everyone for there advice.I hope this thread helped you. Good luck with your build.
PCN00B
April 4, 2012 1:27:53 PM
one last thing chaz i've decided to go with the antec hcp-750 at pc world as a power supply but thanks for your suggestion http://www.pcworld.co.uk/gbuk/antec-hcp-750-atx-psu-750... and thanks you've been a real help. ps is their a way i can help you like rank up on the forums. anyway cheers ps how do i close the forums now??
Chaz21
April 4, 2012 3:22:11 PM
PCN00B said:
one last thing chaz i've decided to go with the antec hcp-750 at pc world as a power supply but thanks for your suggestion http://www.pcworld.co.uk/gbuk/antec-hcp-750-atx-psu-750... and thanks you've been a real help. ps is their a way i can help you like rank up on the forums. anyway cheers ps how do i close the forums now??It looks good and Antec is a good name. I think the thread is closed after you pick a best answer. I'm happy if I was any help to you. Good luck to you and with your build.
johnpaul182
April 4, 2012 10:06:02 PM
If your from the Uk, i'm not sure newegg will deliver to you, I'll list a few sites for you to have a look at;
http://www.aria.co.uk/
http://www.scan.co.uk/
http://www.ebuyer.com/
PCN00B
April 5, 2012 11:07:26 AM
johnpaul182
April 5, 2012 11:45:51 AM
Tavo_Nova
April 5, 2012 11:50:51 AM
PCN00B
April 5, 2012 6:25:39 PM
Chaz21
April 5, 2012 7:53:18 PM
PCN00B said:
i agree with you tavo nova but i want this pc to last me 4 -5 years so im best going with a graphic card that will still preform well in future games and the 6850 will become obsolete before the 6870 so i'm saving money in the long runSaving money (even in the long run) is always a good thing.
Anonymous
May 14, 2012 5:37:42 PM
- First build, not sure if components work together. Forum
- First Time Build - Need Help Checking Components Work Together Forum
- Building a DAW for the first time: will these components work? Forum
- SolvedAre these pc components going to work good together when I build them into a desktop computer? Forum
- SolvedFirst build/ components list- some advice Forum
- Solvednew build will these components work together Forum
- First Gaming PC components - Will they all work? Forum
- SolvedFirst time build, looking for opinion on components Forum
- SolvedFirst Build: Help picking components? Forum
- SolvedAre these good components for a first build? Forum
- SolvedWill this build work (main concern: will my components fit in the Zalman Z3 plus?) Forum
- SolvedFirst Gaming Build, Checking to see if Components are Compatible Forum
- SolvedFirst time build, help me pick components! Forum
- SolvedFirst Build. Are the components good together? Forum
- SolvedGood components for my first build? Forum
- More resources
