Audio is not working. Could a sound card fix this?
- Sound Cards
- Speakers
- Audio
Components
Last response: in Components
oleanderx
July 17, 2012 1:19:46 AM
The only time I am able to get audio is when I plug my video card into my TV via HDMI. Whenever I plug in Speakers or headphones I get nothing. My computer detects they are in but still nothing. My playback devices available are Realtek Digital Output, Speakers and Samsung DLP-1. Does anybody have any insight of what the problem could be? I was thinking my on board audio is shot.
More about : audio working sound card fix
captaincharisma
July 17, 2012 1:47:09 AM
oleanderx
July 17, 2012 1:52:43 AM
- My Integrated Realtek Audio HD was Toast. Will Buying an External USB Sound Card Fix This Problem? - Forum
- Sound doesnt work for built PC will a sound card fix it? - Forum
- Would a new sound card fix audio problems? - Forum
- Could my Sound Card be the cause of static (audio) build up? - Forum
- Do i need sound card for front panel audio to work? - Forum
captaincharisma
July 17, 2012 1:59:06 AM
oleanderx
July 17, 2012 2:00:57 AM
captaincharisma
July 17, 2012 2:04:18 AM
oleanderx
July 17, 2012 2:06:04 AM
captaincharisma
July 17, 2012 2:11:38 AM
right click on my computer and then when the window appears left click on device manager on the left. in the next windows click the + next to sound video,and game controllers. then you should see something with the name of your sound device right click on it and then click uninstall. after that close everything and restart the computer. once it reinstalls the sound driver check for sound
m
l
oleanderx
July 17, 2012 2:15:26 AM
captaincharisma said:
right click on my computer and then when the window appears left click on device manager on the left. in the next windows click the + next to sound video,and game controllers. then you should see something with the name of your sound device right click on it and then click uninstall. after that close everything and restart the computer. once it reinstalls the sound driver check for soundI have 4 of them named "Nvidia High Definition Audio" and then 1 named "Realtek High Definition Audio". Which ones do I uninstall?
m
l
captaincharisma
July 17, 2012 2:17:58 AM
oleanderx
July 17, 2012 2:34:20 AM
hard to know without seeing it just do it to all of them. they will all get reinstalled anywayA few things happened after doing that. Now in my Playback devices it lists, Digital Audio (S/PDIF), Headphones and Speakers. I have headphones plugged in and it has a green check mark next to it and it says audio is there but I hear nothing. And in my device manager under sound it lists the same 4 "Nvidia high Definition Audio" and now another one says "High Definition Audio Device". Still no sound after uninstalling and re installing the drivers.
m
l
captaincharisma
July 17, 2012 2:41:13 AM
oleanderx
July 17, 2012 2:47:26 AM
captaincharisma
July 17, 2012 2:48:55 AM
oleanderx
July 17, 2012 2:54:18 AM
smorizio
July 17, 2012 3:04:08 AM
you have to disable the nvidia audio drivers. there telling the pc to use the hdmi/video card as the output for sound and not the mb. the green port on the back is going to be the output port for your sound. go to your mb vendor web page and download the sound drivers for your mb. in windows go to the control pannel and under nvidia sound click disable.
m
l
oleanderx
July 17, 2012 3:12:02 AM
smorizio said:
you have to disable the nvidia audio drivers. there telling the pc to use the hdmi/video card as the output for sound and not the mb. the green port on the back is going to be the output port for your sound. go to your mb vendor web page and download the sound drivers for your mb. in windows go to the control pannel and under nvidia sound click disable.Would the Audio Driver's here be the correct ones? http://www.asrock.com/MB/download.us.asp?Model=Z68%20Ex... Also, how would I disable the Nvidia audio drivers? Through the Nvidia control panel? This is all it shows. http://gyazo.com/fac19759fd524727217d5a2e65584dde
m
l
captaincharisma
July 17, 2012 3:39:03 AM
oleanderx said:
Would the Audio Driver's here be the correct ones? http://www.asrock.com/MB/download.us.asp?Model=Z68%20Ex... Also, how would I disable the Nvidia audio drivers? Through the Nvidia control panel? This is all it shows. http://gyazo.com/fac19759fd524727217d5a2e65584ddein playback devices you would just right click on the NVIDIA device(s) and left click on "disable"
m
l
oleanderx
July 17, 2012 4:02:44 AM
in playback devices you would just right click on the NVIDIA device(s) and left click on "disable"I don't see anything related to Nvidia in my list of Play back devices. I can disable the 4 "Nvidia High Definition Audio" in the device manager but I still cant hear anything. I really do appreciate you helping me out with this.
m
l
oleanderx
July 17, 2012 4:22:01 AM
smorizio
July 17, 2012 6:18:44 AM
m
l
gamerk316
July 17, 2012 12:13:06 PM
oleanderx said:
2 of them say "Not plugged in". Realtek Digital Output is the default device and is highlighted.Thats the wrong output. The Digital Output is for using the SPDIF port, not the analog outputs. If using a standard 3.5mm TRS connection, you want "Speakers (Realtek High Definition Audio Device)" as the default output device.
m
l
oleanderx
July 17, 2012 1:18:40 PM
smorizio said:
http://www.realtek.com.tw/downloads/downloadsView.aspx?...newest driver 2.70 is there.
I downloaded and installed that but still nothing. I am still trying to figure out how to permanently disable the Nvidia audio drivers though.
m
l
gamerk316
July 17, 2012 1:46:34 PM
^^ You shouldn't have to. I have THREE different audio outputs on my system right now, and they don't conflict at all:
Realtek Onboard
NVIDIA HDMI
ASUS Xonar Xense
If you wanted to kill the NVIDIA audio driver, you need to go to the control panel->programs, uninstall the NVIDIA drivers. You should get an option to uninstall just the audio driver. Again though, thats not the problem.
Realtek Onboard
NVIDIA HDMI
ASUS Xonar Xense
m
l
oleanderx
July 17, 2012 5:27:19 PM
gamerk316 said:
^^ You shouldn't have to. I have THREE different audio outputs on my system right now, and they don't conflict at all:Realtek Onboard
NVIDIA HDMI
ASUS Xonar Xense
Could my onboard audio be dead?
m
l
gamerk316
July 17, 2012 7:55:06 PM
oleanderx
July 17, 2012 10:28:55 PM
- SolvedHD Audio not working, RMA board or get sound card? Forum
- Mic not working through front panel audio with sound card Forum
- SolvedDoes a Sound Card Adapter Fix Static Issues? Forum
- VIA HD Audio Sound Fix Forum
- how to fix audio when i dont have sound video and game controller Forum
- SolvedComputer freezing because of no sound. Should I get an audio card? Forum
- Audio output on laptop gone will an external sound card work Forum
- Solvedshould i disable onboard Audio when i install a sound card? Forum
- SolvedHey, Does anybody know where I could get a driver for my MK608738mx/db sound card Forum
- Solvedgraphics card makes an annoying vibrating/rattling sound, how to fix? Forum
- SolvedCould you guys help me decide on a sound card? Forum
- Sound/Audio not working, how to know if hardware broken? Forum
- SolvedAudio delay between onboard and sound card? Forum
- SolvedRealtek Audio Driver Environment Editor / Get better audio fron on-board sound card Forum
- SolvedRealtek HD Audio Not Working! Only Recieving Sound From HDMI Cable Forum
- More resources
Read discussions in other Components categories
