Will this system work?
6 answers Last reply
More about will system work
  1. I dont know what happened there was more to it.
  2. Hey there,
    All the components you have listed are fully compatible with each other and should work fine!
    However, be aware you will need a graphics card as this board has no onboard graphics connectors!
    And don't forget a hard drive ;)
    Hope this helps
  3. Also what a lot of people forget is an optical drive!
  4. how about this one?will this work?
    motherboard:gigabyte GA-990XA udr3
    processor:amd fx x6-6100
    cooler:coolermaster hyper 2012 evo
    graphic card:gainward geforce GTS 450 2 gb ddr3
    memory:4gb ddr3
    memory:4gb ddr3
    Hello zihero5127.
    Yeah, that's all compatible and should work fine! However, one thing to bear in mind is that the motherboard MAY need a BIOS update in order to make it work with the AMD FX Chips. It's definitely compatible with FX chips, but it doesn't necessarily mean it's compatible straight out of the box.
    Hope this helps
  6. Like I said up there ^^ your going to need an optical drive, unless your planning on installing your desired OS by usb.
Homebuilt Systems
