Stock CPU cooler not fitting cooler mount
I jus bought a AMD phenom ii x4 965 BE anf a biostar TA990FXE AM3+ mobo but the stock cooler that came with the cpu doesnt fit the cpu mount on the board, any suggestions?
5 answers Last reply
More about stock cooler fitting cooler mount
  1. Hi :)
    Yes it does....
    All the best Brett :)
  2. hmmm maybe im missing something but it seems to be the heat pipes getting in the way and the manual doesnt help for *** :c
  3. OHH i got it i didnt know you had to push the clamps through *total first time builder*
    the stock cooler always gets people, since it doesnt use screws.
    well its good to know im not alone, screws would seem to bemuch easier
CPUs Cooling Phenom Biostar
