Solved
Do sound cards need power from the PSU?
  • Sound Cards
  • Power
  • Components
Last response: in Components
July 17, 2012 11:50:03 PM
Hello,
I'm thinking of buying a sound card and I was wondering if you will need power from the PSU to power the card? Or will I just need to put it in the PCI slot on the MOBO and it'll be good to go?
The sound card I'm thinking about buying is this: http://www.amazon.com/ASUS-Xonar-Channels-Interface-Sou...
More about : sound cards power psu
Best solution
July 17, 2012 11:54:46 PM
There are a couple that do, but that isn't one of them.
July 18, 2012 6:19:01 AM
So this sound card that I'm buying won't need it right? Just double checking.
m
l
July 18, 2012 6:19:49 AM
Correct. :)
m
l
July 18, 2012 10:10:13 PM
Best answer selected by TGT_Gaming.
m
l
July 18, 2012 10:10:26 PM
DJDeCiBeL said:
Correct. :)
Alright cool, thank you.
m
l
July 18, 2012 10:11:58 PM
You're welcome. :)
m
l
