Archived from groups: rec.photo.digital (More info?)
"Perk" <perk@waverunner.net> wrote in message
news:sPGdnWyLxMBy3i3fRVn-ig@wavecable.com...
> Hi all,
> I bought the "FL-CB04" flash cord that is supposed to be compatible with
> my Oly C700 UZ and thought everything would work fine.
> The trouble is that it doesn't trip the strobe at all. Is there an
> internal setting that I have to change ?
> Thanks much,
> Perk
Are you using the FL-40 strobe or another brand of strobe. The camera's
book says an
FL-BK01 and FL-CB01 bracket and cord are required for that. I couldn't find
any mention in the book on a FL-CB04 flash cord but it does say that some
aftermarket strobes will not work because they are not wired properly. I've
had pretty good luck using a Vivitar 283 with a digital peanut slave trigger
and setting the camera to the manual mode for ISO and shutter speed and
letting the auto mode of the flash take care of the rest. I have a PDF
file of the entire instruction book which I could send you if you are
missing your instruction book. It is however, a little over 10MB. I don't
remember where on line I found it. Probably the Olympus site.
Tom.
>>Hi all,
>>Thanks much,
>>Perk
> book says an
> Tom.
The FL-CB04 cable is for connecting the 5 pin "off-camera" flash fitting
to a unit having a PC type connection.
My problem may be that the old "Twinklite" that I was using isn't
compatable with it to begin with.
I'm heading into Seattle today and will make a stop at Glazers, the pro
shop there, and see if they can dope it out.
