So iam going to upgrade my computer to an intel core i5 2500k and an asus z77 sabertooth and i was thinking of geting water cooling (cpu loop only).
After some reserch i found out that my case (zalman Z9 plus) does not support a dual rad.
i was planing on going for XSPC Rasa 750 RS240.
Although i plan to upgrade my case around christmas to a NZXT Switch 810.
So is there anyway i could mount the XSPC Rasa 750 RS240 in the zalman z9, i know people have mounted it on top of the case with the top part off and i do not mind mounting it there for the time being untill i upgrade.
I was also thinking is it possible to take out the hard drive cage and mount it on the bottom or in the front (i have seen this done).
Also is it possible to mount it on a desk or somthing?
I have seen it being mounted off the back of the case with long screw.
I do not wish to cut anything but if i have to i may.
I was also thinking could i go with a single 120mm rad for the time being and upgrade to a 240mm rad when i get the case, and if so is a single 120mm rad enough to overclock the i5 to about 4.7-4.8Ghz?
