Power supply for graphic card
Hello
I wanted to take a graphic card. I decided to take Raedon HD 5670 1gb.
I think my psu is not capable of handling it... i saw that 230v is written on my psu.I have a 6pin connector. I don't know much about this things but i got to know that i have a 6pin connector by software cpuid... can you please suggest me way in which i can .
I have also got something like this from my computer by the same software
Hardware monitor Nuvoton NCT6776
Voltage 0 0.89 Volts [0x6F] (CPU VCORE)
Voltage 1 1.12 Volts [0x8C] (VIN1)
Voltage 2 3.36 Volts [0xD2] (AVCC)
Voltage 3 3.36 Volts [0xD2] (3VCC)
Voltage 4 1.05 Volts [0x83] (VIN4)
Voltage 5 1.03 Volts [0x81] (VIN5)
Voltage 6 1.05 Volts [0x83] (VIN6)
please tell me if i can put hd 5670 on my desktop
thanks in advance XD
8 answers Last reply
More about power supply graphic card
  1. When you tell us what the make and model of your power supply is, we can tell you if it's good enough to power a 5670......
  2. look at the back of the psu there will be a lable in that lable there will be written that how much watt your psu has.:)
    How much watt it has means nothing. It's the amps on the 12v rail and what temp the ratings are taken at....which is why we need to know the make and model.
    A generic 750w psu MIGHT put out 500w if your really lucky. A quality 750w psu put's out a real 750w+.
    Oh and it's the side of the psu, not the back.
  4. @geekapproved oh sh** i forgot to write there how many amps on 12v because watt means nothing and the power is most important.
  5. all that is written there is 230v :(
  6. Open the side of the case. You should see a label on the PSU.
  7. ]Im guessing you have an oem computer which means no your psu is not enough for that card here is what I recommend.
    Corsair CX430 on newegg.com
  8. thanks i am going to take the psu mentioned by jmccarty13
Radeon Power Supplies Graphics Cards Graphics Product
