Using a not original power cord for PSU
Last response: in Components
- Used the wrong power cord for my psu. Forum
- can i use power cord 250 v in psu 100-240vac Forum
- Is it ok to use my PSU's power cord? Forum
- Use PSU power cord or GPUs ? Forum
- SolvedMSI GTX 770 with 2 8-pin power connectors, okay to use two separate cords from PSU? Forum
- Solved250V power cord to power PSU labelled 100-240VAC Forum
- Solvedwhen using an atx extender do wires have to be the same gauge as the atx cord from the psu? Forum
- SolvedNeed a suitable uk power cord for evga 600w psu (came with us plug) Forum
- Power Supply - Can using the wrong power cord damage it? Forum
- SolvedPower cord problem (couldn't find PSU forum) Forum
- SolvedPSU power cord question? Forum
- SolvedSwitch Dead | Possibly from wrong power supply cord used? Forum
- Need help regarding PSU power cord Forum
- using power cord while gaming on alienware m14x. Forum
- SolvedUnderstanding power cords (is it OK to use this power cord for this old amp?) Forum
- I'm using Original Power Supply that came with my DellINSPIRON Computer,NO POWER,nada!! Your suggestion(s) PLZE!!! Tnx in Adva Forum
- GPU needs two 6pin power plugs, can i use two on the same cord? Forum
- Need help identifying a power cord for connecting a GTX 650 Ti Boost to a Corsair HX750 PSU Forum
- HTPC PSU advice using and original xbox case Forum
- PSU power cord is 2 feet too short...is this extension ok? Forum
- More resources
Read discussions in other Components categories
