Solved
PC Crashing Problem help!
Last response: in Systems
Hello I've been having some problems with my computer it's been crashing lately and it's where my computer makes like a restart sound like a lightsaber powering-up then powering-down and my screen goes black.
I looked around and I thought it could have been from overclocking so I took out the battery and reset my bios to factory defaults and it seemed to stop after a while but it's doing it again and it generally happens when my computer is locking up from trying to do to much stuff or it happens when I'm on voice chat in steam and playing a game..
Another thing I should mention is that I bought all my parts except my hard drive and my powery supply so I thought maybe the PSU is dying but I don't have the tools or experience to test that so I'm wondering if I can get some help on it.. I did some heating tests and checked my temps which all seem to be ok.
Just give me directions on what I need to do before I go out and buy another PSU, mine now is a 400-watt.
More about : crashing problem
Homebuilt system Expert
You'll get a lot more help on this board if everyone knows what they're dealing with so please list your components. (CPU,GPU,PSU,MOBO,RAM -etc.)
Graphics: AMD Radeon HD 6670
Ram: Ripjaw G-Skill Ddr3, I have 4GB of Ram
Motherboard: Biostar A880G+
CPU: Amd Athlon II X2 250
PSU: Antect SP-400(Model Number) 400-Watt
Related ressources
Yeah it sounds (and looks) like it might be your PSU. It's kind of "lite" in the amp department. You've got a good brand name though. Make sure it's replacement has a good name also.
Custom Built yep, PSU is on the bottom and I've had the case open the whole side of it is off and it's got.
I checked my heating with programs and that doesn't seem to be the problem.
Unless it's PSU overheating?
I still think your PSU is a little on the "weak" side, in amperage your about as far as you can go. The item above that I suggested is the exact same size (physically) as the one you have now so I know it'll fit if you decide to go that way.
Ask the community
