Closed
Are these parts compatible
Last response: in Components
Best solution
Where do you see that it's not?
From the ASRock site.
Quote:
AM3+ FX FD4170FRW4KGU(BE) 125W Bulldozer 4200MHz 2200MHz 2MB x2 8MB B2 P1.10
Anyway, everything looks ok, I just don't like the thought of using the PSU that comes with that case (Thermaltake PSU's aren't very good, and I'm thinking the one that comes with that case is lower quality than even a normal TT PSU). It has enough wattage (supposedly), but I still wouldn't really trust it.
Related ressources
It is this processor
AMD FX-4170 Processor - Quad Core, 4MB L2 Cache, 8MB L3 Cache, 4.20GHz (4.30GHz Max Turbo), Socket AM3+, 125W, Fan, Unlocked, Retail box, 3 year warranty.
also what is the matter with the thermal take power supply?
does everything else look good
Just lower quality than some brands. The lower end TT's tend to not last very long, and I would say that the one that comes with that case is almost definitely a low end model.
It would help to know exactly WHICH model it is, but I have doubts that it's any good. The 7770 isn't exactly a power hungry card though, so it's not like you'll really be pushing it to its limits. The problem is that it may only provide something like 350-400W on the 12V rail and not 500W (I would almost guarantee it).
But yes, everything else looks ok to me.
OK, I just checked, and it's a dual rail unit with 14A on rail 1 and 15A on rail 2, for a wattage of 168W available from rail 1 and 180W available from rail 2.
Those don't add together for the total, so it's actually only capable of even less than the 348W combined (probably closer to 320W or a bit less). Not good from a supposedly 500W unit.
With that said, I think it'll do with a 7770, but I just wouldn't trust it.
Ask the community
