Hey there!
The fan of my new Gainward GeForce GTX 570 Phantom suddenly decided to not throttle down anymore. I would guess its running at an average 65%. I tried the Gainward Tool "EXPERTool" to throttle the Fan... I can throttle it up to 100% and it works fine. If I choose dynamic the fan speed IN THE TOOL is shown decreasing 1% per second but at some point the fan of the graphic card does not reduce the speed anymore. Minimum should be 30%. What to do?
Temp is 30°C.
- Gainward GeForce GTX 570 Phantom
- Gigabyte GA-Z68XP-UD3, Z68
Any ideas?
Temp is 30°C.
Any ideas?
