http://www.hkepc.com/bbs/itnews.php?tid=699767
Hope it is not the rumour or "gossip at the Inq".
Cant see the 65nm parts being better than the 90nm processors in the end.
higher core clocks better memory handling,more efficient core.
i could go on about what id like to see but i am hopeful it will have at least a 5% perf boost.
All available data today says that the highest clocked K8 will be the 90nm CPUs.higher core clocks
I don't think that AMD have changed anything spectacular on the 65nm die shrink. If they could just improve the intercore communication by skiping the L2 cache to RAM writeback, that might boost the multithreading perfromance a bit in some cases.better memory handling
Yes, if you are talking about the energy efficiency.more efficient core.
It is the same architecture with same the features as Rev F. How do you expect any perfrormance boost?i could go on about what id like to see but i am hopeful it will have at least a 5% perf boost.
Not trying to pick a fight, but I would like to point out there were noticeable improvements in performance between the AMD 64 3000+ Winchester core and the AMD 64 3000+ Venice cores that came out later.
Both were 90nm chips. The Venice core was just a later revision with AMD's usual minor nips, tucks, adjustments, added extensions, etc.
I don't have any hard data handy, but I saw similarly configured machines running (same MB, same brand and model memory, same video card) and I would say the difference between the Venice and Winchester core chips (same mhz, same cache) "felt" like about 5 percent.
How many months have passed between the release of the AM2 socket chips and the planned Dec. 5 release at 65nm? I would argue that's enough time for AMD to have also included a few minor revisions -- no major changes to the architecture, just the usual minor improvements introduced with a new stepping.
Are we going to get any worthwhile overclocking increases? Or is this going to be like those energy-efficient models, who almost overclocked worse than their stock counterparts?
~Ibrahim~
I have to point out that the 130nm => 90nm transition for Athlon64 is from Newcastle to Winchester.
X-Bit Labs have published a report that the performance stayed the same for the transition.
http://www.xbitlabs.com/articles/cpu/display/athlon64-90nm_12.html
thats what i was getting at .
if its cost effective we will see a slight boost.thats just common sense.
in marketin 65nm doesnt really mean much ,but when you do a minor improvement over the same socket design,and give a slight boost,it becomes more marketable.
am2 wasnt shouted about for its slight bump with ddr2 800,as a matter of fact if you werent an enthusiast youd be asking am what?am2 oh.
the chances of amd wanting to provide a slight boost are massive;the only drawback is the probability factor.and apparently these chips are on the doorstep already so with no engineering samples coming out for benches the right assumption is any boost will be next to nothing or there is no boost at all.
they can do 5% they are not stupid.but,time versus money;it may be wiser to wait for the next revision of am2.for them.
when the first intel 65nm came out they were netburst cpusI don't know about better overclocking, when the first intel 65nm came out they were horrbile and just as bad at overclocking as the netburst cpus.
WTF are you smoking mate? Intel has held the "reputation" crown for quite some time, though AMD has held the "performance" crown for some timeOfcourse AMD is a more reputible company and will do something to the architexture.
