Closed Solved
I need serious help! (once again...)
I really don't know which GPU to get.
There is the:
-XFX Radeon HD 6870 ($150/normally $190)
-PNY GTX 560 Ti ($185/normally $260)
What I'm asking is, will the 560 Ti worth $35 more for the games I'm playing:
-COD
-Battlefield
-Crysis
A lot of games like that... will it really increase my performance?
Thank you :) ;) !
10 answers Last reply Best Answer
More about help once again
  1. What resolution?
  2. I think its worth it but I don't like PNY. you are looking at a 10-15% improvement with a 560ti over a 6870.
  3. I will be playing at 720p (my 47" TV)... I don't know what that is. High? Medium?
    Why don't you like PNY? They have a lifetime warranty which I like :) .
    And also, say I got a 6870 and didn't like the performance as much.
    Would a 6870 + 6850 out perform a 6970?
  4. Best answer
    My friend had a PYN 460 which overheated like crazy. I think he got it replaced and was still hot.
    yes a 6870+6850 will out perform a 6970 but I'd suggest not using 2 different cards for crossfirex as the performance gets even more jumpy than normal crossfire.
    Okay...
    I'll get a 6870, and then if I need to upgrade, I will :) .
    Thanks for your help ;) .
    According to this:
    http://www.anandtech.com/bench/Product/330?vs=290
    the 6870 out performs the 560 Ti in like 10%-20% in games, and is close in like 60% of the games.
    So, if I do want to upgrade, get another 6870 or what?
  6. just a note: but XFX also has a lifetime warranty
  7. yes you should get 2 6870s when you want more performance.
    if you get a 6850+6870, the 6870 gets lower to perform like the the 6850 but since they aren't equal things often screw up and give you studdery results.
  8. Best answer selected by tw23.
  9. Thank you guys :) !
    I think I'll get the 6870 and see if I need more performance over a year or two.
  10. This topic has been closed by Mousemonkey
Graphics Cards Games Graphics
