Help me check a build before I order! :)
3 answers Last reply
More about help check build order
  1. Just found the right place for this.. sorry!
  2. This will all work together. One think I'm not too fond of is the hard disk. You ordered a disc with only 16MB cache memory. You really should get a disk with 32 or 64 MB cache memory. It'll make a big difference in system performance.
    http://cdon.se/hemelektronik/western_digital_caviar_blue_wd7500aalx_750gb_7200rpm_32mb_3.5%22_sata-3-14186889
  3. i think your graphics card is going to blockade the sata ports because the video card is triple slot its big so there will be no room for you to plug the hardrive and cd rom in everything else is good it will be allright if you buy a dual slot graphics card make sure you get a large case too
CPUs Build Compatibility Hard Drives Processors
