Case Opinion . Need help
  • Power Supplies
  • Cases
  • RAM
  • CPUs
  • Components
  • Product
Last response: in Components
a b ) Power supply
a b à CPUs
July 20, 2012 10:07:48 AM
I just decided on my new rig but PSU and case is missing.
Im at a total of 300-350 Euro and till know i have spent 196 for CPU / RAM /MOBO
This leaves space for 150 euro for CASE and PSU .
Carbide 500 R
Carbide 400 R
CM 690 II Advanced 3.0
Nzxt H2
More about : case opinion
a b ) Power supply
a b à CPUs
July 20, 2012 10:32:17 AM
So i buy 500R over other cases ?How about CM ? I was reading some reviews and it was an imba case. Also cool looking and high quality.
Jack i would like some help even about the PSU if u can.
Thnak you
a b ) Power supply
a b à CPUs
July 20, 2012 10:55:37 AM
Carbide 500 R is great.
Whats your budget : )
There is ton of great cases.
a b ) Power supply
a b à CPUs
July 20, 2012 11:03:41 AM
My budget is 150 Euro PSU +Case ;)
a b ) Power supply
a b à CPUs
July 20, 2012 11:06:02 AM
How many GPU's?
Post the GPU and CPU info.
a b ) Power supply
a b à CPUs
July 20, 2012 11:11:33 AM
I3 - 2120
Asrock B75 Pro3-M
G.Skill 8GB 1600
HD 6870 (Will be added later maybe december)
4x 160GB Hdd
a b ) Power supply
a c 104 à CPUs
July 20, 2012 11:18:03 AM
JackNaylorPE said:
500R
http://benchmarkreviews.com/index.php?option=com_conten...
and not the 400R
http://www.tweaktown.com/reviews/4408/corsair_carbide_s...
So now it comes down to the fact which I couldn't bring to you in the Carbide 400R review, and that is which of the two Carbide chassis' are the one to buy. ...... The 500R is well worth every extra penny over the 400R.
That's bad advice, since the main reason they recommend the 500r over the 400r is the US shipment costs. OP appears to be buying in Germany, so shipping costs (and prices in general) are obviously going to be completely different.
a b ) Power supply
a b à CPUs
July 20, 2012 11:23:30 AM
@nikor At that price i was thinking about XFX Core Edition Pro 550W for 54 Euro as it is a better psu than CX. so if i buy that this leaves space for around 100 euro for case.
Mostly bettwen CM 690 II Basic 64E /Advance 84E and the Carbide 500R for around 94E .
If anyother case plz tell me.
a b ) Power supply
a b à CPUs
July 20, 2012 11:24:28 AM
Why to spend 78 Euro for a 550 W psu ? I dont need it to be modular.. XFX 750 is 80 so that is no sense.
a b ) Power supply
a b à CPUs
July 20, 2012 11:25:06 AM
I didn't see that PSU at all : )
a b ) Power supply
a b à CPUs
July 20, 2012 11:29:09 AM
So to end this i have 193 Euro for Mobo/Cpu/Ram
need case and psu and lets say Psu is the XFX at 55 Euro .
So money for case is around 90 Euro. Mostly bettwen CM 690 II Basic 64E /Advance 84E and the Carbide 500R for around 94E .
a b ) Power supply
a c 104 à CPUs
July 20, 2012 11:38:34 AM
From your link the 500r seems to be 93€ plus shipping. Honestly, I'd get the 400r and use the money left over for the other components.
a b ) Power supply
a b à CPUs
July 20, 2012 12:17:42 PM
@nikorr i dont like storm scout.
@sakkura 500r is better anw .. dont need more components .. i just want to chose bettwen CM 690 II basic vs advanced .. but i think ill be getting the advacned for just 80 E
a b ) Power supply
a b à CPUs
July 20, 2012 12:20:42 PM
Cool : )
I like the 500r the best.
a b ) Power supply
a b à CPUs
July 20, 2012 12:21:59 PM
@nikorr ima go watch some reviews :p  just one more thing CM690 II Advanced + XFX 750 or 500R + 550 W ?
a b ) Power supply
a b à CPUs
July 20, 2012 12:24:20 PM
550W is enough with quality PSU for your GPU.
a b ) Power supply
a b à CPUs
July 20, 2012 12:25:11 PM
500R is best one from those 4 cases. IMHO :D
a b ) Power supply
a b à CPUs
July 20, 2012 12:27:38 PM
ok thank you dude ill be going on it :)
a b ) Power supply
a b à CPUs
July 20, 2012 12:29:02 PM
Good luck : )
a c 158 ) Power supply
a b à CPUs
July 20, 2012 12:30:36 PM
A good quality 500W is enough for a single HD 6870; it requires a 500W PSU with at least 32A on the 12V rails and two 75W 6-pin PCIe power connectors. That XFX core is a great little PSU with plenty of reserve power for OC of the CPU/GPU and hard to beat at that price point.
a b ) Power supply
a b à CPUs
July 20, 2012 12:35:59 PM
@rugger I found it with disconut at 44 Euro so i already orderet it.. other parts will be orderer on monday.. than case its still hard to choose :S but reviews will bright my way :)
a b ) Power supply
a b à CPUs
July 20, 2012 1:13:34 PM
Yes both 690 and 500r. Idk im so confused :S
a b ) Power supply
a b à CPUs
July 20, 2012 1:16:01 PM
The design is much nicer on the 500R.
And the cable management is just great. No mess.
a b ) Power supply
a b à CPUs
July 20, 2012 1:18:05 PM
And when u have more HDD's,
for me its a must to have the HDD's facing this way. Its much easier to plug and unplug them and keep the cables out of the way.
a b ) Power supply
a b à CPUs
July 20, 2012 1:20:20 PM
Y but i forgot about fans -.- my Speakers are Black with blue LED and carbide comes w/ white LED meanwhile the CM 690 come with blue LED . thats a prob
a b ) Power supply
a b à CPUs
July 20, 2012 1:24:05 PM
Hey, as long as u like it.
Its u, that will be looking at it : )
a b ) Power supply
a b à CPUs
July 20, 2012 1:28:32 PM
I am looking at some youtube videos and that LED is not that white :D
I have heard about some ground problems for cm 690 that when u touch the case it resets ... is that true
a b ) Power supply
a b à CPUs
July 21, 2012 12:24:00 AM
Ok just something more guys. Is the X-Dock Hot Swappable at cm 690 ?
