I just built a system and it wont display through the gpu, but it does just fine through the mobo port for the cpu. The gpu is a 6950 that i was using earlier today on my previous build. Im not sure if the mobo has a deffective connection, or the psu was deffective.
so heres the specs if that helps:
CPU-i5 2500k
GPU- AMD 6950
Mobo- Gigabyte Z68AP-D3
PSU OCZ 700 watt
CPU-i5 2500k
GPU- AMD 6950
PSU OCZ 700 watt
