Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > [Solved] HELP! Best Graphics Card and PSU Without Changing MOBO On GM5474
Forum Graphics & Displays : Graphics Cards [Solved] HELP! Best Graphics Card and PSU Without Changing MOBO On GM5474
Best answer from geekapproved.
Hey Folks,
I need some quick advice. I've spent the weekend researching this on the forum and have not come up with an answer to my satisfaction. I'm going about this more from a standpoint of what my mobo and cpu can handle more so than being tied to a strict budget. The nVidia 8500gt GPU in my Gateway GM5474 system is bad. So I'm going to go ahead and do an upgrade while I'm at it. The Motherboard is an ECS MCP61P-AM, PCIe 16, Memory is 1024 MB PC5300 DDR2 667MHz SDRAM, AMD Athlon 64 X2 6000+ processor, Delta 400w psu.
I would like to get some quick advice on GPU, PSU, CPU (if needed) and Memory before rebates and sale prices go away tomorrow. What would be the best graphics cards this unit could handle without changing the motherboard or cpu? Would like to have the capability for gaming without getting too crazy.
I am looking at the Saphhire HD 6870 and something along the lines of a Corsair TX 650/750 Modular PSU. Where to find the best deals along with comments and suggestions are greatly appreciated! Will consider either nVidia or AMD Radeon. From what I've read, the midrange AMD Radeons perform great on less power, but I'm listening.
Reply to dragsterslayer
This would be a good upgrade and you could use the power supply you have now
http://www.newegg.com/Product/Prod [...] 6814161397
You can't really upgrade your cpu. Gateway's are basically throw away computers.
Your next move unfortunately would be a new computer.
Message quoted 1 times
Message edited by geekapproved on 01-30-2012 at 11:19:45 PM
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
Thank you for your quick response. I don't have a problem changing the PSU. If I do that, will this system handle a better card than the HD6670? Seems you are saying don't waste the money on this system and start another.
Best answer
Your cpu is too slow to use anything faster than a 6670.
It would be a major improvement over what you have now, and you wouldn't need a new psu.
Yes I'm saying don't waste any more money on that computer.
It would be a major improvement over what you have now though.
Friend, I will take your advice. I'm done with retail throw away computers. I'm gonna try my hand at a build next. Newegg also has the Sapphire version HD6670 Low Profile for the same price. From what I've read, Sapphire seems to be the top version for AMD cards. Do you have an opinion either way?
Best Regards
Yeah sapphire is fine.
I went ahead and ordered the HIS HD6770 Low Profile because of the 2 fans. Should be a little quieter with better cooling. Also I will add 2 x 1GB memory sticks for a total of 4GB, even though it will probably only show 3 to 3.5 for this OS. Each slot has a maximum capacity of 1GB. Well, I guess that's about it for this computer. Thank you kindly for your time and advice! :hello:
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1485 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 4 hours ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
