Solved
Best side window case
  • Power Supplies
  • Cases
  • Graphics Cards
  • Components
  • Product
Last response: in Components
July 20, 2012 9:18:35 PM
I'm looking for a case that has a side window, because I really like the way it looks. My budget is $150-ish. I am currently looking at an antec eleven hundred. By graphics card is eleven inches long (asus gtx 680 cuii top) so the base has to be pretty roomy. I dont care if it is a mid tower or full tower just nothing over 27 inches.
More about : side window case
Best solution
July 21, 2012 12:34:46 PM
Perhaps something like this? http://www.newegg.com/Product/Product.aspx?Item=N82E168...
If I were in the market @ that price range, I'd try to sport metal casing if possible. Are you looking for something more flashy than what I linked?
a b ) Power supply
a b U Graphics card
July 21, 2012 1:11:00 PM
I would say the haf 932 black edition but good luck finding it anywhere.
http://www.coolermaster-usa.com/product.php?product_id=...
Hmm...
perhaps a 932 advance refurb for $80
http://www.cmstore-usa.com/haf-932-advanced-black-steel...
with the 932 amd edition side window for $10
http://www.cmstore-usa.com/haf-932-amd-limited-edition-...
and I found the 932 black's side panel too for $20
http://www.cmstore-usa.com/haf-932-transparent-acrylic-...
Wow gettting a 932 for under $100...
m
l
July 21, 2012 10:15:47 PM
Best answer selected by jimmy_dog.
m
l
