Hello,
I just bought a new graphic card (link), open the case, installed the card in the PCI Express slot, then I realized that the power cord was a Molex 4 pins like that:
but the only connections coming out of the PC power supply were SATA connections .
For now, I used a old PC which has Molex power connections, opened it up, put on the side of the other PC and connected the graphic card power supply to the old PC power supply, it looks ridiculous.
I see 2 options:
1. buy a power convertor like this one:
http://www.computercablesource.com/sata-power-adapter-4-pin-female-molex-to-15-pin-male-sata-power-connector-serial-ata-1765.html
2. bring back the graphic card to the video store
Are there other reasonable options?
Thanks!
I see 2 options:
Thanks!
