His iceq hd 4870 vs gigabyte gtx 285..how far the difference for power consumpti
  • Graphics Cards
  • Gtx
  • Power Consumption
  • Gigabyte
  • Power
  • HD
  • Graphics
January 31, 2012 12:31:05 PM
.how far the difference for power consumption?i used his iceq hd4870 with gigabyte superb 720w.but now want to change with gigabyte gtx285.is it possible to use same power supply?
More about : iceq 4870 gigabyte gtx 285 difference power consumpti
a c 119 U Graphics card
January 31, 2012 12:51:39 PM
Your power supply should run ANY single card configuration(With 42amps or 504watts watts on its 12 volt rails).
The GTX285 will not take more then 20-30max(less at most game loads) watts more then your current card.
m
l
January 31, 2012 12:59:41 PM
thank you so much for both of u nukemaster n sunnk
m
l
