I'll start with my system specs, then outline the problem(s).
Motherboard: Biostar TA990FXE
Processor: AMD FX-6100
Memory: Mushkin Enhanced Redline 8 GB (2 x 4 GB) 240-Pin DDR3-1600 Kit
Graphics: 2 x Gigabyte Radeon HD 6950 1 GB
Hard Drive: OCZ Vertex Plus 60 GB SATA II SSD (Windows 7 64-bit installed)
Hard Drive: Western Digital Caviar Black 750 GB
Hard Drive: Seagate Barracuda 160 GB
Optical: Lite-On iHAS124-04 24x DVD Burner
Case: Rosewill Challenger-U3
Power: Corsair TX650 V2 650 W
Ok, I built this computer last week. I breadboarded it first to check all of the components. Everything was working. I assembled it all into the case and everything worked. I set up and installed the operating system, and got it all up and running. I used it for about 24 hours, playing games and having no problems whatsoever.
I woke up the next morning to see the monitor dark. I tried to press the power button, and the system would power on for just a fraction of a second, then go off. It wasn't so much powering on as sort of "sparking" up for a brief second. The LEDs would flash and the fans would start to spin during the spark, but then it would not power on. I thought it might be the motherboard shorting on the case, or the PSU. I checked the PSU and it was functioning normally. I also removed the motherboard and went back to the breadboard, but it still would not power on. I rechecked the CPU to make sure everything was properly seated there and that no thermal compound was shorting on the motherboard.
I reassembled it, and found that if I repeatedly pressed the power button very quickly, the system would actually power on. The fans would work, and the first two LEDs (from the left) on the motherboard were lit up. But there was no system beeping, even when I removed the memory to test it. I tried resetting the CMOS, and popping the motherboard battery out and in.
After resetting CMOS and fiddling with the battery, I powered the system back on and the first and second LEDs (from the left) on the motherboard were flashing, whereas before they were solid. This is now the state of the system. The first two LEDs flash, and I get no system beeping at all.
So, basically, I'm unsure what is broken. Also, I have no idea what caused this all in the first place! I've built two systems before and never had these issues. I overclocked the CPU using the "automatic" setting with the software the motherboard came with. I have never overclocked a CPU before, and I'm worried this may have caused a problem. I have no clue.
