Solved
I been having CPU fan problems. Not urgent though.
  • Homebuilt
  • CPUs
  • Systems
Last response: in Systems
April 8, 2012 9:00:09 PM
OS:Microsoft Windows 7 Home Premium SP1 64-bit
Case:NZXT Phantom PHAN-001WT White Steel / Plastic Enthusiast ATX Full Tower Computer Case
PSU: CORSAIR Professional Series HX750
Motherboard: ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K
Cooler: COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
SSD: Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
HDD: Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Video Card: SAPPHIRE 11196-02-40G Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card (OC Version)
Thermal Paste: Arctic Silver 5 Thermal Compound and Arcticlean (just to let you guys know what I used.)
Well, I've been having issues with my CPU fan. When I start up my PC after a longer period of time (maybe about 8 hours or more), my PC boots and then it goes to the American Megatrends screen saying CPU fan error and F1 to set up. I then restart the PC and then it goes to starting Windows normally (usually. There are instances where I was forced to restart 3-4 times). I was worried the first time that it wasn't working and my CPU would overheat but, the CPU temps were regular, from 26 C to about 34 C. On the ASUS motherboard bios, it is setup to ASUS optimal performance, the most right option in EZ Mode. I looked into the advance settings and sometimes it seems that CPU fan isn't running fast enough (less than 600 rpm). That happens but also the sometimes the CPU fan isn't even detected, even when in regular mode. So, my question is, what should I do? Is the fan faulty? Or is it that the ASUS motherboard is just demanding too much RPM?
More about : cpu fan problems urgent
Best solution
a b B Homebuilt system
a c 159 à CPUs
April 8, 2012 9:50:52 PM
Look for the smartfan setting in the hardware monitor section and calibrate your fan. I use quiet mode after I finish the calibrate option. You may also have a weak motherboard battery. The cr2032 "button battery" sells for $2-3 at many outlets. Even walmart or target may carry them.
a c 118 B Homebuilt system
a c 79 à CPUs
April 8, 2012 11:50:54 PM
Just out of curiosity. You should be able to turn off CPU fan monitoring, which would revert the fan to running full blast all the time. If you have a stock fan, its probably going to be noticeably loud, but the BIOS should leave you alone. Also, are you sure you have the fan plugged into the main CPU fan header?
m
l
April 9, 2012 2:41:56 AM
I see. I just wanted to see if it was normal. I don't think any of my parts are faulty... probably. So, yeah I guess I'll just change the monitoring setting. I think my MB was forcing the fans to a higher RPM whenever I restarted, so I'll change that. Thanks for your responses.
m
l
April 9, 2012 2:42:22 AM
Best answer selected by Admas.
m
l
