I need help on building a gaming rig that fits under my tight budget of less than 1300 USD. I managed to find most of the parts, but I still need help finding a case and if these parts are a good combination.
Parts not needed- Mouse, keyboard, monitor, OS, Optical drive
Processor- i5 2500k http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Motherboard- ASRock z68 Extreme3 Gen3 LGA 1155 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
RAM- G.SKILL Ripjaws X Series 8GB (2 x 4GB) http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
PSU- CORSAIR Enthusiast Series TX650 V2 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Optical Drive- Not needed I have one
Storage- Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767
CPU cooler- Not needed, I will be buying later on in the year.
GPU- Evga GTX 680 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130768
Case- I am not sure which case to go with as I was originally going for a HAF 912 with optional 2x 200mm front and top fans, but I fear it may not be enough to cool my components to under 70C. I was then looking at the HAF 932 Advanced and was wondering if it would be enough.... I am open to suggestions, however please don't recommend anything above 140 USD and the HAF 922
Other Thoughts- I will be overclocking later and I do not want Crossfire or SLI. I will be gaming on a 22 inch monitor. I prefer Newegg or Amazon only for computer parts.
Thanks in advance!
Also please rate the build too and tell me if the parts are overpriced or if there is a less expensive better solution
Thanks in advance!
