Help Picking i7
Last response: in CPUs
I was wondering what a best part I can get for 300-350 is I was looking at the i7-2600K and i7-3770K
also a card with no integrated graphics would be nice because I will never use them.
More about : picking
PanicMaster85 said:
I was wondering what a best part I can get for 300-350 is I was looking at the i7-2600K and i7-3770Kalso a card with no integrated graphics would be nice because I will never use them.
Both the 2600k and 3770 have four cores with hyperthreading. The main difference is the 3770K is clocked slightly higher and has better integrated graphics. If you are going to be using a discrete video card you have no use for integrated graphics so I would go with the I7-2600k
Related ressources
- Need help picking a cheap i7 motherboard. - Forum
- I7 3770K only picking up 2 logical cores. Please help !!! - Forum
- I7 Build, Need Help Picking Blu-Ray Burner! - Forum
- New i7 Build Help needed picking LCD - Forum
- Picking water cooling parts help ! - Forum
The 2600k is Sandy Bridges the 3770k is Ivy Bridges. Both are good the Ivy Bridges is the 3rd generation I core processor and like I said Intel upped the clock speed and improved the integrated graphics with Ivy Bridges. The main negative with Ivy Bridges is it runs a little hotter than Sandy Bridges which won't really make a difference unless you plan to overclock. The I7-960 while still a very, very good CPU is kind of old it's socket 1366 and is first generation I core processor. If you are going to go all out and get an I7 you might as well get a 2500k or 3770k. What are you going to be doing with this computer? Are you going to use a seperate video card and are you going to overclock?
PanicMaster85 said:
I will not overclock(at least if i don't have to) I am going to be gaming mostly and I play games with open maps such as dayz, gta IV, bf3, skyrim, fallout. I do render videos but only for youtube not muchalso 2500k is i5 and there is another but i cant remember the name i think it is 3570K?
If all you are doing is playing games and going on the internet there is really no need to get any I7 either Sandy Bridges or Ivy Bridges. With the I7 you are paying an extra 100 dollars for hyperthreading and extra CPU cache, two things that games don't really make use of right now. You would be better off with the I5 2500k and putting that saved 100 dollars towards a video card.
Yes that is the newer Ivy Bridges I5, the I5 3570k. Like the 2500k it is a quad core CPU with an unlocked multipier so it can be overclocked. Like the I7 Ivy bridges it is clocked slighty higher than it's older cousin and has the newer HD Intel graphics. I would still go with the 2500k. There really is no need to go with Ivy Bridges you aren't going to be overclocking and you aren't going to be using the newer integrated graphics.
I just got the i5-3570K, and it's slick.
I OC'ed it up to 4.3 GHz with no issues, and it's still as cool as a panda.
The iGPU came in handy because my graphics cards still have not arrived so I'm using the integrated graphics to run a 1920x1200 display and the processor wouldn't have batted an eyelid if it had one.
I render videos too, but since my graphics cards aren't here yet, I haven't given it a try. The thing is HyperThreading is that the added cores are not physical cores and therefore, you only get about 20 maybe 30 percent of performance increase.
Let's assume you give each render thread 2GB of RAM (which is minimal for HD video). Assuming 8 threads, that's already 16GB of RAM, which leaves nothing for the compiler process itself. So unless you want to drop coin on at least 32 GB of RAM in order to allow you to give 3GB of RAM to each render thread, don't worry about HyperThreading and save some money by getting the i5-3570K.
kshitijmd said:
I just got the i5-3570K, and it's slick.I OC'ed it up to 4.3 GHz with no issues, and it's still as cool as a panda.
Ok but I think I will stick with the 2600K
oh by the way rds1220, I was talking about the 2700k
http://www.amazon.com/Intel-i7-2700K-Quad-Core-Processo...
PanicMaster85 said:
haswell? please... continue, I am... Intrigued
http://en.wikipedia.org/wiki/Haswell_(microarchitecture)
Related ressources:
- ForumNeed help picking out a heatsink for my core i7 sandy
- ForumOCZ or Corsair for i7 build. Need help picking .
- ForumNeed help picking remaining parts
- ForumNeed help picking SAS vs SATA
- ForumMentally Handicapped Person Needs Help Picking Parts 4 1st Liquid Rig!
- ForumHelp with picking memory
- ForumHelp - new to picking parts :D
- ForumPicking Some Components
- ForumHelp picking GPU around 350 or 400$
- ForumNeed help with picking graphics card
- ForumNeed help picking cpu for my upgrade
- ForumWhere can I find a good mechanical keyboard?
- Forum[Solved] Need Help picking out PSU
- ForumHelp picking parts
- Forum[Solved] Need help picking a case
- More resources
