I have decided to get this Zotac GTX 670 AMP! Edition gfx card (not the stock Zotac card)-
My case that I'm getting is the NZXT Lexa S-
NZXT Lexa S LEXS - 001BK Black Steel ATX Mid Tower Computer Case
Now as you might know the problem is that the ZOTAC GTX 670 AMP! gfx card is extra long, thick & the heat pipes are protruding out giving it more width (due to copper heat pipes) & therefore more space is needed in the case to fit it properly & for the left side panel to be installed properly.
I know the card will fit in length but I'm not sure whether this gfx card will cause any problems with the installation of the left side panel window being installed due to it's protruding heat pipes design?
So plz help me! Will the left side panel be installed properly or will the heat pipes make contact with the left side panel & interfere with it?
Don't...
Bump posts
http://www.tomshardware.com/forum/283384-33-read-first
Don't...
Bump posts
