[Unsolved] Looking for parts to rebuild and revive my dead PC.
I'm not sure where to begin with this but I've experienced BSOD a few months ago and gave up on using my PC. (I think the CPU is out)
What I plan to keep:
Budget Range:$500-600
System Usage from Most to Least Important: I just want to have a PC up and running again for gaming purposes (Dota 2, D3, Guild Wars 2), and streaming (if possible).
Parts Not Required: keyboard, mouse, monitor, speakers
Country: United States
Parts Preferences: Not sure
Overclocking: Maybe
SLI or Crossfire: Maybe
Graphics Card: GTX 260
Corsair DDR3 Ram - 24GB (4 memory sticks 6 GB each)
Cooler (Don't remember which kind but it's worth a bill)
I'm not too sure what I need to fill in the blanks with besides the Motherboard, CPU, Power Supply.
Any help is appreciated.
Thanks in advance!
10 answers Last reply
More about unsolved parts rebuild revive dead
  1. So... what do you want to keep? I'd recommend upgrading your graphics card to a 6870 (correct me if I'm wrong, techies). I'm assuming you can't wait until April 29th since your PC is dead, so I'm going with current hardware:
    CPU: i5-2500k - $190
    GPU: 6870 - $170
    Motherboard: Extreme3 Gen3 - $120
    PSU: I found a great deal on this 750W one: - $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817703027
    Are you keeping the case? If not, get a HAF 912. I think you're set! As long as you have an HDD, RAM, and a CPU cooler. Do you have your HDD? I didn't include that.
  2. Yeah, I have an HDD, thanks for the response!
    GPU: 6870 - $170
    http://www.newegg.com/Product/Prod [...] 17-703-027
    If I waited till next month, do you have something else in mind? I can probably wait it out. =)
    two words, Ivy Bridge.
  5. ^Yep. Basically, you'd buy an i5-3750k for about $240 (I think), and an ASRock Extreme4 Z77 motherboard for about $150 (it's on newegg right now). Just make sure you buy all of your parts simultaneously!
  6. oh and also, if you wait a month, you could also save a bit more for your budget to pay for maybe, slightly higher end parts, video cards, hard drive, heck you might even want some new case fans, a little extra budget cash is never a bad thing.
  7. By the way, updates on the price:
    i5-3750k is going to be $225
    ASRock Extreme4 is $140
    GPU: 6870 - $170
    That link for the 750w PSU won't work :cry:
  9. Argh... I love how I didn't even put the name of it. I changed it... it's the PC cooling Silence MK II Silver rated 750W...
  10. Oh.. those are pretty nice
New Build Systems Product
