chadbry Distinguished Jan 28, 2012 206 0 18,710 Feb 1, 2012 #1 I would think no. But I can't find the answer. Will a 2gb card use more power than a 1gb card?? I'm guessing if it did it would be a very small diff.
MagicPants Distinguished Jun 16, 2006 1,315 0 19,660 Feb 1, 2012 #2 That's right. There will certainly be a difference, but it won't be very much. Clock speed and things like that will make much more of a difference. check out tom's charts: http://www.tomshardware.com/charts/2012-vga-gpgpu/23-Power-Consumtion-Load,2981.html If you check the Gainward Geforce GTX 580 Phantom 3gb vs the 1.5 gb you see it makes a difference of 6 watts (297 vs. 291) Upvote 0 Downvote
esrever Splendid Dec 27, 2011 5,391 0 26,160 Feb 1, 2012 #3 yea, ram runs with very little power. Upvote 0 Downvote
