New Monitor Problem
I got a brand new monitor yesterday.
Acer 23' LED S232HL HDMI
My old monitor is a Dell M991 VGA
My problem is that the new monitor wont find a signal unless the old Dell is plugged in.
If i shut down the computer with the Dell still plugged in it works fine. If i shut off the computer and unplug the Dell, the Acer doesn't find a signal. I am using the HDMI cable for it. Although it does have a VGA cable and and DVI cable as well. I havnt tried any of those two. I want to use my HDMI cable.
I am currently only using my on board video which is an ATI Radeon HD 4290 512 mb. I am going to be upgrading that in a week or two.
Is there some settings im missing? I hope it is a simple solution.
I could use both monitors, but i dont really have use for using 2 monitors. I would just rather use the new one.
Anyone have this problem before? or any solutions?
1 answer Last reply
More about monitor problem
  1. BTW, my OS is Windows 7 Pro. If that helps.
Radeon Monitors Cable Dell Graphics
