Input signal out of range
Graphics card Master
Monitor Expert
Remove the GPU and try to use the onboard IGP if the PC has one. Also clear the CMOS/BIOS and then go on with your tries.
It would be a lot more helpful if you would have given the specs of your friends rig, like Mobo, GPU, Monitor, etc etc
thanks for the reply problem is solved, i installed windows with using another monitor.
refillable said:
Probably he did something that the monitor or graphic card can't handle, reset your CMOS.
Ask the community
