Power Bricks
  • Power Supplies
  • Laptops
  • Hewlett Packard
  • Power
  • Components
Last response: in Components
July 23, 2012 10:38:39 PM
I don't know what exactly to name this, but my power brick for my laptop crapped out on me and all the power bricks where expensive, and im going to send my pc to hp to get it fixed/possibly the power brick. my old power brick was rated at 18.5v and 3.5a (64.75w) and this really ghetto power brick (can change the voltage, but pc wont charge (according to windows or the power indicator) unless its set to 18v, its rated at 4.5a (81w) is it safe to leave it plugged in at that amount of watts (they said not to so for now I won't) or if I turn the voltage down to 12 (the lowest that is below 65 watts (54 i believe) and the next highest is 15 (67.5). is it safe to leave it at 54 watts and have it plugged in, also if you know will hp replace a power brick?
More about : power bricks
a c 721 ) Power supply
a b D Laptop
a b α HP
July 23, 2012 11:27:04 PM
The volts is the important thing you need 18,5 volts 4.5 amps means it will charge faster but the computer will only pull the watts/amps it needs.
m
l
a c 166 ) Power supply
a b D Laptop
a b α HP
July 23, 2012 11:51:55 PM
+1^
As stated above, the wattage rating is simply the 'capability' of the charger. The more wattage, the better its capability to charge. As long as you match the voltage and it can provide the necessary current (A) supply to charge the battery, you should be OK. That is, of course, if the charger is UL approved or some equivalent of same.
m
l
July 24, 2012 3:42:59 AM
It isn't certified, also I don't see any ul logo, only this ce logo, in going to look that up, for now I'll keep it un plugged
m
l
July 24, 2012 3:46:44 AM
I found it out, ce is the European equivalent, according to wiki, I'm going to look up their standards and compare it to ul to be safe
m
l
July 24, 2012 3:57:24 AM
I looked it up, it isn't as strict as the ul, but most ce products would be ul certified, should I trust it though? I'm sending my pc in in a few weeks and I'll see if i can get a new charger, but i did do a ram change (it was with a professional certified HP person around, but technically not him, would that void the warranty, also can I trick HP into allowing it if i say it was him. This pc only matters to me 1 day a week every week and a few weeks each summer and a week for winter, so if It's really fucked up I have another laptop, but It's not the end of the world. But for now I practically need it, my phone dies fast when I use flash.
m
l
a c 296 ) Power supply
July 24, 2012 4:04:55 AM
What is the charger you are using? Is it from a real company? I know antec had a power brick with selectable output voltages.
I see this is yet another case of HP tech support not knowing a damn thing, a 90W brick will work just fine with your laptop even if your old one was a 65W, the system just needs 18.5 Vdc to be available from the charger and it will draw just as much current as it needs, no more. My HP laptop replacement charger was a 90 W when the one it shipped with was a 65 W because the new DV 7 series came out and had 90 W chargers that still worked for my model.
As for the ram change, it should affect the warranty on the power brick or the laptop, just stick the old ram back in before you ship it back to them if you have to, i don't think there are any stickers or anything you have to break to change it.
m
l
July 24, 2012 6:41:36 AM
It's from nobutech, they seem to make allot of products judging by Google images gunna look into it further though
m
l
a b D Laptop
a b α HP
July 24, 2012 4:58:29 PM
I'd go for it. My aging laptop's charger died and I ordered a 'brand name' replacement charger. It turned out to be the same charger as the 'no name' item that I passed on at half the price. They are all made in the same Pacific Rim country anyway.
m
l
July 24, 2012 11:44:33 PM
Alright I'll leave it on, but i unplug it because the charger gets HOT, hand I don't trust it as much as my other laptops charger when running that hot, but then again toshibas run hot as hell
m
l
a b ) Power supply
a b D Laptop
a b α HP
July 25, 2012 12:47:32 AM
The last time I needed a new brick charger I got it off e bay and it was under $4....
edit - that was just last year. my dughters dog chewed thru her cord.
m
l
a b D Laptop
a b α HP
July 25, 2012 12:56:08 AM
Power bricks in general run hot! They are electric transformers with no real way of cooling.
m
l
July 25, 2012 5:15:36 PM
Well my Toshiba uses the whole brick as a heat spreader, this one only get blazing hot in the center
m
l
a b D Laptop
a b α HP
July 25, 2012 5:39:25 PM
If it is too hot to hold in your hand, I would not take a chance.
m
l
July 26, 2012 9:54:45 PM
It's not too hot but It's kinda getting close
m
l
a b D Laptop
a b α HP
July 26, 2012 10:05:36 PM
Then, it is probably not a problem. Those power supplies like that have no means of cooling. And the heat is trapped in the sealed molded case. Any cooling is strictly via convection thru the case. They normally get uncomfortably warm when in use. If it is hot when not in use (laptop is turned off), then you have a problem.
m
l
a b D Laptop
a b α HP
July 26, 2012 10:45:26 PM
I have several laptops and the temperature ranges but the biggest brick on my work laptop (portable workstation) gets the hottest, lets call hot to hold but not burning.
m
l
July 27, 2012 12:43:59 AM
Mine is getting close to not be liable to touch, gunna see if i have a temp monitor that i can use to see the temp
m
l
a b D Laptop
a b α HP
July 27, 2012 12:54:49 AM
Heck, my laptop itself gets too hot to leave on my legs sometimes. That's normal.
m
l
