How do I add another computer to my wireless system
nancy46
Hello,I'd like to add another computer to my wireless system but don't remember my password - what can I do?
answer
Last reply
More about computer wireless system
Hello and welcome toTom's Hardware Forums.
From a PC whicch is connected wirelessly, or cable to the router from the one which won't connect thhen go Start then Run in XP - or use the Windows key plus R in Vista and Windows 7, then type in the following into the Open box, including all the spaces:-
cmd /k ipconfig /all
then press Enter and from the black form that shows up, take a note of the numeric code beside the Default Gateway icon - something like 192.168.0.1.
Type exit to close the black form.
Open Internet Explorer and enter that code into the URL address bar as though it was a website. You're then at the login page to the router's settings utility and admin will usually be the login with either admin or password as the password but your router's instruction manual will help you there.
If you're in, seek out Wireless and then Security and take a note of the key. Sometimes it may be a passphrase, some a simple set of letters and others a hexadecimal code. You also may as well note which level of security it is - WEP, WPA or WPA/PSK 2 and then either AES or TKIP. Your computer will already know this but it's handy information to store. Note also that hexadecimal only contains numbers from zero to 9 and letters a to f so there's no confusion of I and O with 1 and 0.
Keep a note of that security key in My Documents and also outside the computer.
If you need more help after this thread is inexplicably closed down, feel free to PM me.
Configuration
Wireless
Computers
Wireless Networking
Related Resources
- How do I add another computer to my wireless system
- Wireless System
- New system, new wireless
- Duracom wireless home security system
- Wireless drivers for emaches computers
- Adding another computer to my wireless system
- Connecting lap top to wireless system
- Printing to a wired printer from a wireless system
- HOW WE CAN FIND WIFI SECURITY KEY FROM SYSTEM
- Can ur wireless button or software go out on your hp computer
- Where can I find the password for a wireless system
- How can i access cd room of another system in a wireless networking using two ub
- New built computer, wireless doesn't work
- How to know if computer is compatible for wireless router
- Wireless.
- Wireless with 1 Computer
- How to add computer to wireless network linksys
- Adding wireless without the interneet
