Closed Solved
Cooling fan issue
Hello:
My O.S. is Dell dimension 3000, win xp, home ed., sp3
I recently re-installed windows and some applications so now my computer works very well and FAST - BUT.........
the cooling fan is always on and runs very hard. I am wondering if anyone can explain what the fan is trying to do and why it runs so hard these days. The
CPUID hardware monitor app. shows: 96° F right now and the fan is blowing pretty hard. There was a time when the fan was much quieter. The computer
seems to be working just about as good as it did when I re-installed things and many virus scans have turned up no malicious problems. When I re-installed
windows, I cleaned out the inside of the tower so I don't believe the fan is trying to make up for accumulated dirt in the tower. Also, I downloaded a Bios updated
driver from Dell and installed it but no change in the fan speed. I'd like to understand what is going on with the fan and, if it's a problem, fix it soon.
Thank you for your help here,
Jim :)
6 answers Last reply Best Answer
More about cooling issue
  1. Your temp is not high (34-36oC), i think its just set to run at full speed, in the bios isn't there an option to change fan speed?
  2. Best answer
    It's behaving just like my sister's system did. We opened it up, and whew, was there alot of dirst and dust in there. Cleaned it out well and the fan returned to normal.
    I will check the Bios thing out. But for now, I am seeing a lower fan speed after THOROUGHLY cleaning up the insides of the tower to include the heat sink. It's now running at 36° C consistently.
    Same here. I thought I had cleaned it pretty good but still found a lot more debris in the heat sink and in the front panel. The fan is running at what I would call normal right now and the temp. is 36° C.
    Thanks for responses everyone,
    Jim :p
  5. Best answer selected by jimrich.
  6. This topic has been closed by Mousemonkey
Cooling Fan Components
