Troubleshooting a power up problem
  • New Build
  • Power Up
  • Systems
Last response: in Systems
April 10, 2012 9:03:05 PM
Hi all,
I am hoping someone has experienced the problem I am having and can point me in the right direction.
I am installing a new MB and CPU in my HTPC. I have built 20 or so PC's over the years so I am a bit perplexed as to what I might have done wrong on this one.
I am installing a Gigabyte GA-Z68MA-D2H-B3 and an Intel i3 2105 CPU. The PS is a Seasonic 620W.
I get it all together and when I hit the power button the leds light up and the fans start spinning for approx 2-3 seconds then they shut down. I checked the power connections to the board and they seem right. Any suggestions?
More about : troubleshooting power problem
April 10, 2012 9:12:38 PM
No gpu (other than the 2105)?
m
l
April 10, 2012 9:16:08 PM
No I am utilizing the onboard GPU.
m
l
April 10, 2012 9:36:14 PM
Work systematically through our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-postin...
I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
If not, continue.
The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
Breadboard - that will help isolate any kind of case problem you might have.
http://www.tomshardware.com/forum/262730-31-breadboardi...
If the system POST's here, you have a case shorting problem.
Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
Make sure you plug the CPU power cable in. The system will not boot without it.
I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
If no beeps:
Check for line power at the PSU input. Extension cords, power strips, and power cords do fail.
If you have power and no beeps, suspect components in likely order are PSU, motherboard, and CPU.
Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
The green wire will always have 5 volts on it. When you press the power switch, the voltage should drop to 0 volts.
The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
http://www.youtube.com/watch?v=5FWXgQSokF4&feature=yout...
A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
If the system beeps:
If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card. If you get this with motherboard graphics, your motherboard is bad.
Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card. In this case, you will POST successfully (single short beep). But your monitor will display a "missing signal" message.
In that case, the first thing you do is to test the monitor and data cable with another system to make sure it works. If the monitor works, the video card is bad. If you have motherboard graphics, again, the motherboard is bad.
m
l
April 10, 2012 10:43:30 PM
Thanks for pointing me to the guide. Very comprehensive.
After a few hours of troubleshooting it turns out to be a defective memory stick. Because it was a power issue I had that as more of a remote possibility but live and learn I guess. Again thank you to everyone who gave advice.
m
l
