Sign-in / Sign-up
Need help
  • Cache
  • RAM
  • Overclocking
July 24, 2012 6:43:20 AM
Hello,
If cache chips are faster than RAM, why don't we built RAM using the cache chips?
More about : question
a b K Overclocking
July 24, 2012 6:45:48 AM
What cache chips?
m
l
July 24, 2012 7:06:57 AM
Because Cache memory doesn't hold charge for long enough you would lose all the stored instructions before you got to use them.
m
l
July 24, 2012 7:27:43 AM
Because Cache RAM is more Expensive than regular RAM, a hundred megabytes of the stuff will probably cost around $500. Plus, nowadays, Cache ram is optimized to be very closely linked to the CPU. This makes it so that if you made it big and off the CPU, it just wouldn't perform as fast or as stable. You would need motherboard circuitry that would be able to run as fast as the CPU to support the Cache speeds(it would be as if the motherboard was the CPU, get what I mean?), and no motherboard would be able to go that fast. And if you did have a motherboard chipset that went that fast, then Cache would become RAM, and there would be no Cache... get what I mean?
At one time cache ram was expandable.... the cache chips were on a RAM module and you could upgrade it like RAM modules. But that cache was so slow, modern RAM is now faster than that old school Cache stuff from back then.
m
l
a b K Overclocking
July 24, 2012 7:36:44 AM
Today's RAM is very fast,
we are using it in a way where that speed and bandwidth is not efficiently harvested,
only in benchmarks somewhat.
m
l
