Hello
I have been facing a strange issue and would like to seek your expert help.
Specification:
Motherboard: Intel DG41TY
CPU: Intel Core2 Duo 2.8 Ghz E7400
RAM: Kingston 2 GB , 800 MHZ 240 Pin 1.8V single stick
Harddisk: Two Seagate 500 GB SATA
Optical Drive: Sony DVD R/RW
Power Supply" Cooler master extreme 350 Watt
================Problem Description=================
One day I was working on my computer and found that, CPU temperature was around 62 degree C, so I though I should cleanup by cabinet and FANS
I did that after cleaning fan , Heat sink FAN after removing it. Reinserted the CPU with new thermal paste (Cooler Master HTK001) and restarted the PC, no I can see CPU temp is 38 degree C.
I watched a movie on the PC for another one hrs and temperature where all with range.. CPU 38, Motherboard: 40...
Suddenly my screen freezes in middle of Movie and everything halted, no mouse , keyboard and also the sound from the movie was hanged...hmmmmmm.
I rebooted the PC with reset switch, And the problem arrived, ...
1.) LED on motherboard on stable green
2.) Front panel LED on stable. Blue ( Cabinet came with blue LED)
3.) Chassis fan ON ( front and back connected to motherboard FAn header)
4.) CPU HSF on connected to CPU fan header.
5.) Sound of hard disk spinning, Optical drive working.
still no beeps only silent ( Beep speaker is already soldered in Motherboard) no display, monitor in standby.
========== Trouble shooting done============
1.) disconnected all components and only with 1 stick of RAM , motherboard and CPU
2.) Removed RAM and reseted ( no change)
3.) Removed Processor and rested ( no change)
4.) Removed RAM and started PC, 3 beeps for RAM missing, reinstered RAM , no beep.
5.) Replaced RAM taking to local shop ( no change) with a different working PSU.
6.) Suspected Motherboard Issue : sent RMA to intel, and GOT back saying no problem found.
All connections where done correctly and on the cardboard out of case.
Guys can it be CPU issue..?
Will the motherboard sounds beep if CPU is faulty...I mean When i remove RAM it beeps, but when I remove CPU and RAM both no beeps, so think CPU makes the motherboard Beep.
Please help... I have not replaced the CPU yet...not found same type of CPU nearby.
Thanks for any suggestions
Specification:
