Should a 4 pin power connector be used for a i5 3570K?
Last response: in Components
- Should 4-pin Molex connector or 15-pin SATA power connector be used to connect to SATA HDD? - Forum
- Overclocking i5 3570k - 2x2pin CPU power connector a limiter? - Forum
- gpu needs 6 pin power connector..... what should happend if I don't use a 6 pin p.connector - Forum
- can i use 4 pins of a 8 pin cpu power connector (ATX motherboard is 8 pin connector power supply is 4) - Forum
- Safe to use an 4-pin to 8-pin 12v ATX power connector? - Forum
- SolvedGIGABYTE 880GM USB3, 1 x 8-pin ATX 12V power connector, But I using 4 pin power connector. Forum
- Do I need to use the two 4 pin "cpu" power connectors if I'm using a 20pin + 4pin "p4" connector? Forum
- SolvedCan you use an ATX 12v 4-pin power connector on a 8-pin port? Forum
- SolvedPower Supply -> 10-Pin connector, what is it used for? Forum
- Damaged Jumper and 4-pin power connector what should I do? Forum
- Does using an 8-pin CPU power connector on a 4-pin board result in less amperage? Forum
- Can you use an ATX 12v 8-pin power connector on a 4-pin port? Forum
- SolvedUsed just the 20 pin connector into 24 pin power slot on mobo. Forum
- Solvedcan the core 2 duo power connector fit in the i5 3570k or i need to change my psu Forum
- Solvedhow to connect 4pin cpu power connector with Corsair VS550 550 Watt PSU Forum
- SolvedWill 4 or 6 pins work for my 8 pin CPU power connector? Forum
- SolvedCan't find 4pin power connector. Forum
- Solved24 pin power connector, powers on, add the 4 pin, does not. (Asrock 960GC-GS FX) Forum
- SolvedDoes it matter what 8 pin i use for my CPU power connector? Forum
- SolvedWhat graphics card should I get with a 4-pin connector? Forum
- More resources
Read discussions in other Components categories
