Sign-in / Sign-up
I7 3770k overclocking problem
  • CPUs
  • Overclocking
  • Intel i7
Last response: in CPUs
July 24, 2012 1:28:34 PM
hi , i overclocked i7 3770k to 4.7 ghz with uefi bios in my sabertooth z77 easily but the only problem is that when i opened
cpu id sometimes the cpu core is : 1.6 ghz and sometimes it goes to 4.7ghz . please help
More about : 3770k overclocking problem
a c 116 à CPUs
a b K Overclocking
July 24, 2012 1:36:32 PM
Maybe intel speed step is still enabled (underclocks CPU on idel).
m
l
a c 116 à CPUs
a b K Overclocking
July 24, 2012 1:38:27 PM
m
l
July 24, 2012 1:38:43 PM
what is the solution what should i do now
m
l
a b à CPUs
July 24, 2012 1:41:07 PM
This most likely isn't a bug, but rather a feature. Intel calls it Speedstep, and AMD calls it Cool N' Quiet, but the affect is the same. When idle for a set period of time, the CPU will lower its clock setting to reduce its power draw. So your CPU might register at a significantly lower clock speed, but as soon as there is work to do, it bumps back up to its original clock setting. You can turn this feature off in the uefi settings.
m
l
July 24, 2012 8:19:24 PM
i turned speed step off and reset deffault overclock to down the clock to 3.5 but
the problem still occured the core clock is 1.6 in my desktob and goes to 3.7ghz sometimes and othertimes is 3.9 ghz .
m
l
July 24, 2012 11:32:08 PM
well are you having any laggs while playing games as such? , as in does the speed drop while doing something with the PC ( just to be sure )
m
l
a c 291 à CPUs
a c 114 K Overclocking
July 24, 2012 11:42:45 PM
If it really matters to you to have a max speed OC, go to Control Panel -> Power Options and enable the High Performance power profile.
m
l
