Building a computer. need help!!
im planning to build my own computer and i need someone's opinion on whether the parts i chose are good for it.
GIGABYTE GA-Z68AP-D3 Intel Z68 Motherboard ($100)
Intel Core i5-2500K ($200)
Patriot 4GB DDR3 (1333 Mhz) ($13) x4=$52
EVGA GTX 560 Ti 1GB ($230)
Sony Optiarc 24x DVDRW Drive ($18)
Cooler Master HAF 912 Mid-Tower ($50)
Corsair Builder Series CX600 (600W) ($60)
Western Digital WD10EZRX Caviar Green 1TB Internal Hard Drive - SATA 6GBps, 64MB, OEM $110
3 answers Last reply
More about building computer help
  1. Looks good to me. Either the gigabyte or asrock extreme 3 will work fine.
  2. If you can wait, go for Ivy Bridge (April 29th), and get the i5-3750k ($220), and the Extreme4 Z77 ASRock mobo ($150). If possible, upgrade to a 7850 with your GPU, as well. Make sure you get a CPU cooler! Hyper 212 is great!
  3. Quote:
    I'd definitely say get the 7850 for your GPU - the 7870 is great. Whether you want to wait for Ivy Bridge or not is up to you - you won't notice much if any difference in the CPU and RAM, but you will notice it in the GPU, but the 7850 isn't Gen 3 - it's only the higher end ones that are.
Homebuilt Computer Systems
