Will These Specs Work?
3 answers Last reply
More about will specs work
  1. jamieyates14 said:
    You pretty much got all the basics and they look good. Why don't you just get this:
    http://www.shop.bt.com/products/intel-core-i5-2500k-3-30ghz-lga1155-6mb-79Q8.html?src=15
    it'll probably do all that you will ever need the 2700 to do and a bit cheaper. You could save some "quid" as you guys say. :D
    That's what I've been stuck on, deciding the get the i5 2500k or the i7 2600k. I like the i7 2600k because of the hyper-threading and the 8mb cache... but then there's the price.
    Oh and also it won't just be gaming I will be using the PC for. I will be recording and editing audio/video as well as using fraps a lot.
    Then you did make the right choice with the 2700.
Prebuilt Graphics Cards Components Systems
