Good power supply?
Power Supplies
Graphics
Components
- Product
Last response: in Components
romeodakins
July 24, 2012 10:13:40 PM
I got this power supply http://204.14.213.185/Product/Product.aspx?Item=N82E168... for my system that has A8-3870k with 6670 for dual graphics. My friend says 400w isn't enough and I need like 600w to be safe because the 400w psu will fail in a few months. Is that true? I already got my 400w power supply, it arrived form newegg yesterday and I really really don't want to return it because I will be charged a restocking fee and I'll have to pay 12 bucks for shipping and I'll only be left with 12 bucks refund. I'm thinking of just selling it on ebay for 45 bucks then buying this http://www.newegg.com/Product/Product.aspx?Item=N82E168...
More about : good power supply
- Is this Power Supply good? Replacement for PSU that went up in smoke - Forum
- Is this power supply good enough? - Forum
- Would a 700w power supply be good for this computer? - Forum
- Good power supply for 970 and FX 8320? - Forum
- Is this a good Power Supply? - Forum
romeodakins
July 24, 2012 10:29:02 PM
Well if you look at here
http://www.amd.com/us/products/desktop/graphics/amd-rad...
Go to system requirements it says 500w is recommended for crossfire technology. Are you guys sure 400w is good? And it will last a long time and not die in a few months.
m
l
romeodakins
July 24, 2012 11:00:10 PM
wiinippongamer said:
You're going to be running 1 6770, not 2 of them, the on-chip GPU on the A8 uses very little power, it will be fine.By dual graphics I think they mean crossfiring the onboard a8 with the 6670 because on my box of my processor it says dual graphics, combine with 6670. But are you guys absolutely sure the power supply wont fail or explode by using a 400w power supply? I spent all of my money on this pc and I'm screwed if my pc blows up. My psu is 80 plus certified with 12 rail also. Also it says requirement is 500w if you do dual mode, which is what I'm doing with the onboard graphics and 6670. Mine is only 400w. I used the power supply calculator and only came up with 313w http://i.imgur.com/Sw5vb.jpg I wasn't sure what pci card was so I just chose the soundblaster because is says all models. And for the graphics card, there was no 6650d so I chose 6450 because its close to 6650.
m
l
battler624
July 24, 2012 11:04:01 PM
Best solution
DavidY
July 24, 2012 11:10:19 PM
http://extreme.outervision.com/PSUEngine
The above results in a minimum power PSU wattage between 250 (1xHD 6670) and 300 (2xHD 6670)....calculator recommends a PSU wattage of 300-350.
Antec Eco Neo 400 has a max load rating of 360 watts. So you are good to go if you don't overclock and don't add any more stuff/components to your PC.
HD 6670 have been successfully added to ~300 watt power supplies (not sure about 250 watt PS?). HD 7750 have added to 250-300 watt power supplies. I believe that some of these power supplies are not as well built as your Antec Eco Neo 400 (Seasonic).
Dave
Dave
romeodakins
July 24, 2012 11:25:45 PM
DavidY said:
http://extreme.outervision.com/PSUEngineThe above results in a minimum power PSU wattage between 250 (1xHD 6670) and 300 (2xHD 6670)....calculator recommends a PSU wattage of 300-350.
Dave
Cool so my psu will work? Also, I'm not using 2 6670s, I'm using the integrated 6550d crossfiring with 6670.
m
l
DavidY
July 24, 2012 11:30:20 PM
romeodakins said:
Cool so my psu will work? Also, I'm not using 2 6670s, I'm using the integrated 6550d crossfiring with 6670.It's kinda of a worst case scenario...crossfire two HD 6670....not likely going to happen....but I wanted to see what the calculator would output. Seasonic is one of the best power supply brands out there....I wouldn't be worried. If it was a no-name brand that typically over rates their wattage ratings...I would be worried.
Dave
m
l
romeodakins
July 24, 2012 11:39:21 PM
DavidY said:
It's kinda of a worst case scenario...crossfire two HD 6670....not likely going to happen....but I wanted to see what the calculator would output. Seasonic is one of the best power supply brands out there....I wouldn't be worried. If it was a no-name brand that typically over rates their wattage ratings...I would be worried.Dave
lol my psu isn't seasonic, it's antec, it has 80 plus certified and 12 rail though.
m
l
DavidY
July 24, 2012 11:51:43 PM
Just gonna drop my 2 cents here if it makes you feel better.
You will have 360 watts(30A) of 12 volt power. That is MORE then enough for your system.
Not sure? I run a 5770(thats the same as a 6770 so more power then your card, paired with a i5 750, sure it takes a bit less power, but the video card makes up any differences and then some) on a 300 watt FSP power supply. I have yet to top 200 watts at the wall.
Systems just do not take THAT much power unless they are very overclocked and pushing lots of hardware.
That was Prime95 + Just Cause 2
m
l
romeodakins
July 25, 2012 12:12:36 AM
nukemaster said:
Just gonna drop my 2 cents here if it makes you feel better.You will have 360 watts(30A) of 12 volt power. That is MORE then enough for your system.
http://img841.imageshack.us/img841/3866/apcprimejustcause2.jpg
Thanks
That made me more confident, thanks for the help everyone, I'll use my 400w now.
m
l
romeodakins
July 25, 2012 12:12:53 AM
romeodakins
July 25, 2012 1:08:40 AM
romeodakins said:
Wow, your running i7 with only 224 watts, which psu are you using and how long have you been using it?That all it takes at the wall. The power supply is a Corsair HX850
Overkill? yes, had it was for my last system when i was planning crossfire.
You can never have too much power, but the thought that a single card average system needs 500+(as long as its a quality power supply) watts is just ridiculous. My older I7 920 took more power then the 2600K(this is just a 2500K without HT). It @ 3.8 took more power then a 2600K @ 4.4(For instance with the same card, the 920 took about 150 watts idle and the 2600K is about 90 idle).
With the progress of cpu's I see good things happening in the future
Grab your self a power meter from the hardware store and check it out. Todays systems and power supplies are very efficient.
I have this thing. Sure its not perfect, but gives you an idea.
http://www.upm-marketing.com/products/em100.html
m
l
romeodakins
July 25, 2012 1:41:40 AM
nukemaster said:
That all it takes at the wall. The power supply is a Corsair HX850Overkill? yes, had it was for my last system when i was planning crossfire.
I thought your psu was 224 watts, Corsair HX850 is 850 watts.
m
l
Smallest power supply in a system I have is the 300 watt for the i5/5770 system.
Either way, you are all good with the Antec unit.
http://www.techpowerup.com/reviews/AMD/HD_6670/20.html
m
l
- SolvedWhat power supply will be good for Crossfire 280s? Forum
- SolvedGood Power Supply for my Gaming PC Build? Forum
- SolvedIs a Raidmax Hybrid 630 Watt power supply good for this build? Forum
- SolvedIs this a good power supply ? Forum
- SolvedGood but cheap power supply. Forum
- SolvedGood power supply 500w Forum
- SolvedWould an 850w power supply be good enough for this build? Forum
- Solvedgood enough power supply Forum
- SolvedIs my power supply good quality? Forum
- SolvedGood and Cheap Power Supply Forum
- Solvedis corsair vs 550 power supply good for gaming Forum
- SolvedIs the corsair cx600m a good power supply for a gaming pc Forum
- SolvedGood Enough Power Supply? Forum
- SolvedIs this power supply good quality? Forum
- Solvedgood cheap power supply for R9 290 Forum
- More resources
Read discussions in other Components categories
